Go Back   Home Recording > General Discussions > Mixing Techniques
Old 04-16-2007
ikijapan ikijapan is offline
Senior Member
ikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond repute
autotuned to death
Hey all,
I know the autotune question has been beaten to death, but I had a few specific questions for those with experience.
First, I have a vocal track I'm working with for someone, and we have done like 50 takes, and the performance is turning out great, but there are a few notes that are questionable. I never figured out how to use autotune correctly and it's been sitting on my computer as the biggest, dumbest waste of money I've had so far. I never could get it to sound right. Then I found this video that kind of explains how to use the graphical mode:
http://www.youtube.com/watch?v=WavtqBSEYTc
OK, so that was real helpful. But the guy I'm working with has a very wide vibrato, and the video demonstration has the notes tuned to a flat line straight across the note. I think it sounds a little funny like that. Do you guys use the vibrato feature? or draw in the vibrato manually for pitch corrections?? I wish there was another demonstration somewhere on using autotune...I mean the manual is fine, but I really could use more direction on this.
Also, my last question is, with the graphical mode seeming so NECESSARY, is there even a way to use the autotune rack mount unit? I mean, it seems like it would be useless since it's almost a requirement to use the graphic correction?
Old 04-16-2007
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
try turning the speed down, but with most of the people i work with vibrato is not an issue. so good luck on that.
never used the hardware unit, but to me the "auto" setting is about completely useless. can get away using it on bass sometimes.
audio?
seriously, give me negative rep.
Old 04-16-2007
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
You don't need the vibrato feature.
Hit the button across the top with the thing that looks like an I (right next to the magnifying glass) Use that tool to select the area of the vibratoed note.
Now hit the 'make curve' button (down the left side). Autotune will trace the curve of the performance.
Hit the arrow button on the top. Now, you can grab the middle of the line to move the whole performance to the right note. The idea is to get the vibrato to center on the right note. Or you can grab an end and just raise or lower that end. (this is usefull when someone starts on the right note and starts going flat towards the end).
Now, you have changed the note value without changing the performance.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog AND in .WAV format!!!
Old 04-16-2007
Senior Member
Oh! Nice, thanks Farview. I will have to try that.
Old 04-16-2007
flatfinger's Avatar
flatfinger flatfinger is offline
Use every dam bit!
flatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond repute
If your at home and have unlimited takes and can comp till your hearts content, ; why auto tune????
if you are tone deaf???
must just be in a hurry, right????
Originally Posted by NYMorningstar View Post
This thread is full of as much bad info as it is good info. It should be deleted not stickied or whatever it's called. Save us all the trouble of reading it and maybe we can all get back to important stuff like mixing & mastering.
Old 04-16-2007
gabereding gabereding is offline
Newbie
gabereding is on a distinguished road
Using the vibrato curve thing.
Hey,
If you want to tighten the vibrato so it's not so wide, just select the note with the I-beam selection tool, turn the vibrato knob on the left side of the window down however far you want, and then hit "make vibrato curve".
I think those are the names for those knobs and buttons. I don't specifically remember. Anyways, then you can do like the other guy said, and reposition the curve to be more centered, etc....
-Gabe
Old 04-16-2007
Senior Member
haha, nah man. I took like 50 takes with this guy because I didn't want to use autotune. The guy has great sense of pitch, but there are some REALLY weird arpeggios he is doing with his voice on diminished chords, with wide leaps of over an octave on some parts and it's those parts that he keeps missing. And it's not that he is missing it completely, it's just not as perfect as he would like. I actually think it sounds fine, but he wants it right on pitch on the recording.
And I am NOT going to do unlimited takes. I already went above and beyond on this one. It's about time I learned autotune anyways.
So, we'll see what happens.
Old 04-16-2007
flatfinger's Avatar
Use every dam bit!
Old 04-18-2007
Senior Member
Crap, I'm running into a big problem with autotune. Maybe someone can help. So I am using the graphic mode now, and I know how to get the vocals graphed.
But then after I correct everything (or anything) and play back to the corrected graph, the autotune is slightly out of time with the real vocals and it keeps correcting the wrong part. It's like 2.5 seconds behind. And even if I move the vocals 2.5 seconds ahead from the starting point, it's not exactly on. It's off by like half a second, and then ahead a half a second...another words it would take me forever to time it exactly. What the heck am I doing wrong??
Are you supposed to use autotune as an insert, or a send?? Or neither???
Old 04-18-2007
Farview's Avatar
You can't use graphical mode as an insert or a send. You have to work on the file directly. It's an offline process.
Jay Walsh
Old 04-18-2007
Senior Member
Oh great, farview to the rescue!
So, wait, how do you do that? When I use autotune just by opening the program offline, it doesnt allow me to play the music file. Only preview, or apply. And it wont let me click outside of autotune. It locks it to only autotune?
  #12
Old 04-18-2007
Senior Member
Oh wait a sec. Do I just preview the file to get the data after pressing the track button? And then preview again after making the corrections, and then apply when I am done?? Or am I going about this all wrong
  #13
Old 04-18-2007
Farview's Avatar
What program are you using?
You need to work directly on the file. In Cubase, you would double click on the audio and it would open it up in an editing window, Then right click->plugins->autotune. Then play the track into auto-tune and fix it.
Jay Walsh
  #14
Old 04-18-2007
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
Ive not used Autotune very much but when I used it I found it was best to have the "speed" half way and the other function right next to the "speed" half way up aswell.
I would manually use pitch correction to change the bad notes to closer to the right note then use autotune to smooth things out so the vox sound perfectly in tune.
I used bypass automationfor parts that didnt need the autotune also.
Eck
Million dollar ears.
CRYSTAL MIXING
MY BAND
  #15
Old 04-18-2007
Senior Member
OK, I'm just going about it all wrong. I'll do it that way and I'm sure that will solve the problem.
I am using Cubase as well.
  #16
Old 04-18-2007
Farview's Avatar
Eck
It really all depends on the vocal part. If you have a singer with lots of wide vibrato, that will just ruin it.
Jay Walsh
  #17
Old 04-18-2007
Farview's Avatar
Yup, you actually have to be working on the file itself.
Jay Walsh
  #18
Old 04-18-2007
TerraMortim's Avatar
TerraMortim TerraMortim is offline
How dare you take offense
Location: Seattle, Washington - United State of Nazi Germany
TerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond reputeTerraMortim has a reputation beyond repute
Hey all,
1 word. Melodyne. Check it out. =)
  #19
Old 04-19-2007
Senior Member
Farview!! Help!!!!!!!!!
Crap, I went home and it still didn't work. So I brought my laptop so I can troubleshoot.
So, I double click the vocals, it pulls up a new window with just the vocals. Then I right click and go to plug ins and then it pulls up autotune. At that point, autotune comes up on the screen, and locks out the rest of cubase. Like, if you click outside of the autotune screen, it beeps and you have to ONLY use autotune. I can't play back audio for example by pressing the play button through cubase. I could get the audio by pressing track->preview.
But then it's not going to autotune correctly when I play back.
Do I have some setting wrong in cubase? Should I be able to playback audio through the play button and access all the options of cubase after I open autotune that way??
  #20
Old 04-19-2007
Farview's Avatar
You have to select the part of the track you want to tune. Once you have made the selection, preview will play it. I suggest selecting a phrase at a time.
Jay Walsh
  #21
Old 04-19-2007
Senior Member
OK, but then how do you hear the corrections you made? Do you have to just apply it and then if it's off redo it? And how do you make sure the autotune start point is the same as the playback start point? It seems to get off for me. Do you have to make sure you select a portion of audio IMMEDIATELY before a word starts or something?
For example if I have a song that goes from F# to B on the melody, when I correct it, sometimes the F# correction kicks in on the B and the B on the next note, it's just all off, like some weird delay.
  #22
Old 04-19-2007
Farview's Avatar
You select the part you want to correct, tune it to the grid. (assuming you know what note should be hit) process it and play it back in the mix.
Jay Walsh
  #23
Old 04-19-2007
Senior Member
OK, so there's no way to quickly hear just the vocal before applying, that way I could make sure the vibrato corrections dont sound weird or something?
I'm trying this right now
  #24
Old 04-19-2007
Farview's Avatar
You hit preview and it will play the vocal with the corrections that you made.
Jay Walsh
  #25
Old 04-19-2007
noisewreck's Avatar
noisewreck noisewreck is offline
Sound Destroyer
noisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond repute
BTW ikijapan, Offline Audio processing is covered very thoroughly in the Cubase help system
Originally Posted by George Carlin
Think of how stupid the average person is, and realize half of them are stupider than that.
Originally Posted by Oscar Wilde
All art is useless.
Visit my blog.
Bookmarks
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1995-2010 Audiofanzine except where noted. All Rights Reserved.
