Multi-effects/effects question
Okay, I have a BOSS ME-50 that I recently purchased because I wanted to have the effects it has and figured that would be the way to go. When I play it through my Peavey Classic 30 on the gain channel it's hard to control the feedback and frankly I'm not real pleased with the way it sounds (that's with a distortion/overdrive pedal selected). When I run it through the clean channel I'm still not overly impressed. In fact, overall, I like the amps distortion without the pedal. Is it typical to run a distortion/overdrive pedal on the clean or gain channel? I thought the purpose of a d/o pedal was to push the tubes more while on the gain channel
What I like about this pedal is that I could preset patches which I think would be especially useful for chorus and other modulating effects without having to have a separate pedal for each effect which would = $$$. Anyways any help, suggestions, thoughts, etc. would be appreciated. Thanks to all. |
Throw the presets out! Most of the ME patches are WAY TOOOOOO over the top for my taste. You can run it through either channel. My advice would be to create simple patches..... if ya like the OD from your amp but need delay.... set up one patch just for distorted delay. etc. etc.
Bottom line? With these multi fx boxes.... less is usually more. Just because you can throw 5 different effects into the stew doesnt mean it will taste as nice as if you only used 2 effects. Take some time and really work out what you want it to do, and it will be fine. |
There are so many multi-effects out there now and you can get good sounds out of most of them,the Classic Thirty is a nice amp too. |
I have the same pedal except it is the bass version and I never use presets. I tried to set up a few but I basically just like using it as 3 different stomp boxes. Although it is a bass processor I have a couple of patches that I set up just for guitar and the sound pretty decent. Of course these patches are just distortion/fuzz type settings with maybe a little delay or chorus thrown in.
If you throw too much into a patch it won't matter what amp you use. Let the amp do the talking.
I lost my pants in the fountain. |
Actually I don't use the presets...what I meant is that I like the idea of being able to make my own patches using the different effects available. The main question I had is about the distortion/overdrive pedal. But, maybe my answer is not to use it since I like my amp's distortion anyways. I just thought the overdrive should push the amp more, but to me it sounds like crap and the feedback (+ noise) is uncontrollable. So I'm thinking, do I keep this pedal just for the ability to make my own patches with modulation and delay effects...I know only I can answer that, but just thinking out loud.
Try compression.
I have a DOD FX7 (not the same but similar) which I use mostly through the clean chanel. Like you, I prefer the overdrive from the amp better than what I get from the efx unit. About the only efx I use are delay and compressor so I would probably be better off with a couple of boxes rather than the multi unit. The main advantage I have found is when I need a certain effect for a song I don't have dig through a box of stomp boxes to find the one I need. Multi efx pedals have their place, mine sits on the shelf most of the time.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover |
I don't know if you have an effects loop in your amp, but that's the way I run mine. If you do, set it up so that there is no audible difference when you turn on/off your effects loop with the effects, then just use the delay/reverbs and modulation effects and let the amp provide the distortion. Hope this helps.
B |
pinhedgtr, sounds like a good idea.
One question still unanswered: Isn't the purpose of an O/D pedal to push the tubes more even when on the gain channel? |
#12
I think the main thing is to look at your total package,guitar/pickups/effects/amp.The Me50 is there to add to your sound,not be your sound. I've had all kinds of effects over the years but now I'm finding my favorite sound is just plugging into the amp. ![]() |
#13
B |
#14
All multi-fx pedals I have used sound like crap on the distortion channel, unless your just using some delay or something. I personally don't like using them that much.. Something about the sound just doesn't suit me, unless I am going for some heavy rock.
I play mostly blues and lighter stuff.. so I prefer just a pedal or two straight into a tube amp. |
#15
The problem I have with multi-fx pedals is you usually can not seperate the pedal up to go into the input and the FX loop. I like my wah, overdrive and compression into the input and the chorus, reverb and delay into the FX loop. Lets face it most FX sound bad going into the input.
#16
[QUOTE=Mr. C]I just thought the overdrive should push the amp more, but to me it sounds like crap and the feedback (+ noise) is uncontrollable. So I'm thinking, do I keep this pedal just for the ability to make my own patches with modulation and delay effects...QUOTE]
My trick: choose on your ME a modest type of distortion (like the bluesdrive), keep the gain low and set the volume high. In this way it will work like a booster for your amp. |
| Question about monitoring. | someguy211 | Newbies | 4 | 08-24-2006 21:48 |
| Motif ES Rack voice mode question | Modern_Talking | Keyboards and Sound Modules | 5 | 05-11-2006 06:39 |
| question about mixer | matt's bedroom | Newbies | 3 | 05-04-2006 05:24 |
| First "nice" mic purchase: Question for Mr. Hyatt | Beezoboy | Microphones | 23 | 11-04-2002 18:00 |
| Question about using a 16 ch dig-mixing board w/2ch sound card or multi ch sound card | anppilot | Digital Recording & Computers | 1 | 09-17-2000 18:09 |
