When I lower my guitars vol. the HI freq get cut.
Hi! I put some 1meg pots on my guitar, the thing is only when the vol. is at ten I can hear the full freq range of the guitar. if I lower the vol. the hi freq gets cut. Is there something wrong with the wiring or with the pots?
Also, can i use "no load pots" in the vol. or just in the tone? ThanX |
You can fit a small capacitor somewhere around .001uf from the hot end of the volume pot to the slider, this bleeds in some of the original hf frequencies that are lost when you bring down the volume. Usually you use a no load pot on the tone control, the pot is designed or cut so that it goes open circuit at the end of its travel effectivly removing the pot out of circuit at the end of its travel, thus putting no load on the circuit.
Here's a link from the Kinman site showing a capacitor resistor combination to help decrease the hf loss on lowering the volume......plenty of other info here to..... http://www.kinman.com/images/inside/...t_Wirogram.PDF Another link http://www.kinman.com/images/inside/...e_Wirogram.PDF This explains whats going on......... http://ratcliffe.co.za/articles/volumepot2.shtml Hope this helps Vikki(uk) Last edited by Vikki; 04-12-2007 at 10:16.. |
I know from experience that having a "treble bleed" cap on the volume pot can (not always), increase the highs through the full range of the volume pot, NOT just at low volume levels............Patrick Eggle guitars are one where desoldering the cap is known to "fatten" the sound right across the volume range.
Maybe the solution is in matching the cap to the rest of the circuitry through trial and error. ![]()
--- Humans are analogue beings --- --- Digital information lasts forever......or maybe five years...............................Which ever comes first. --- |
are you really sure that the guitar is losing high end at low volume?
Could it just be the way your ears perceive those frequencies at different volumes? I am not saying this is the case, just curious. I have noticed similar phenomenon over the years with different instruments and was never sure if it was me or the instrument. |
I don´t have this same issue only with my EMG set up .On stage, studio, I can put the vol pot in the level I want, and the tone is the same...
But with my others guitars, I will do (already impress the page), the "capacitor trick" (not "me", I´m dangerous with a soldering iron) Ciro my songs www.soundclick.com/openstation |
Actually, it always does, but the effect gets more pronounced the lower you turn the volume. Personally, I'm not real fond of treble bleed caps, but when I use them I usually use a 500pf cap instead of the more common 1000pf (or .001 μf). It is much less noticeable, but that is why I like it. Light "Cowards can never be moral." M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children." -Aqeela Sherrills http://www.theforgivenessproject.com/ |
Thanks Light..........I was just being cautious in my wording
well, i changed some cables becaouse they were single conductor cables(I dont know the correct term for them, just single wire, very stif), and nothing. I changed the vol pot from 1000 to 500, and problem solved =). well actually my treble in a little stange, it seems to be cuting the low freq too. maybe the problem is the 1000 pot that is still in the tone.
have anyone have had any problem with 1000 pots? |
| Bob Taylor's approach to making guitars | dobro | Guitars and Basses | 19 | 10-15-2005 23:19 |
| Live Mixing Problems... | MiXit-G | Mixing / Mastering | 11 | 04-07-2003 05:17 |
| retracked guitars? | flash2ace | MP3 Mixing Clinic | 10 | 03-21-2003 05:42 |
| VINTAUDIO GIGA CLEAN ELECTRIC GUITARS for GIGA platform | fender123 | Cakewalk / Sonar Forum | 13 | 12-02-2001 18:21 |
| VINTAUDIO GIGA CLEAN ELECTRIC GUITARS for GIGA platform | fender123 | Cubase User Forum | 0 | 12-02-2001 10:51 |
