Bass input
I'm purchasing a bass guitar to add to my songs. Just wondering can I run that directly into the mixer or do I need an amp?
If a amp is needed do I use condenser or dynamic mic?
You were at school and you were pimply and no one wanted to know you. You get into a group and you've got thousands of chicks there. Eric Clapton |
lots of options depending on the sound you want. you can run it straight into a mixer but it wont sound very good so you have to options. run it direct input or an amp. if you run run it direct into the mixer you will want to use a direct box first. this is the easiest method because you wont need to worry about micing an amp and in terms of bass guitar you typically need a pretty good room to record in to get a really nice sound. but running through a di box for bass guitar is very common even in alot of proffesional studios. or if you would rather go through an amp you can do that too but you will want to worry about room acoustics. as for mics there are alot of mics that will sound good on an bass amp dynamic and condesor. alot of large diaphram condesonsers sound good but also alot of dynamics mics like the sm7 and kick drum mics like the d112 it all depends on the sound you want but if your on a budget and just starting out i would really recomond getting a nice bass di box like the sansamp
If you mic an amp to record, you can use either a condenser or dynamic mic. Experiment and decide for yourself which you like better. |
Even if recording for an album, I prefer DI, and I've got some 2k worth of gear for gigging. (gigs I don't even have).
Unless you've got a specific setup and sound you want to capture... I'd go DI. You can get any sound you want through a DI, without the hassle of getting a cab, mics, and a room where NOTHING RESONATES with your cabs. At least on our spaces the drums, other cabs and the wooden walls start ringing when I play.. no use micing that..? ![]()
\m/ WAR OUT!! \m/ |
Depends on the mixer and if it has on-board compression that is halfway decent. Bass is not that hard to get a good sound out of. |
well ok let me rephrase it wont sound as good going straight into a mixer as it will if you use a nice di box first
If you are using a passive bass, you probably want a DI. If you are using an active bass, you are less likely to need a DI, but there are a million variables, from the bass you are playing, the sound you want, what you are plugging into.
I have a very nice active bass (sadowsky) which I generally run through a boutique bass pre, into whatever direct slot. That works for me. |
Thanks
Okay I have a simple small mixer so I will need a DI box.
You guys have preferences on DI boxes? Thanks for your time and help.
Direct into the mixer will depend on the preamp in it.
My old 4 track ahd built in pres that loved bass gtr. My INCA Break out box doesn't. I know this'll sound silly but the Behri Bass DI is quite good. I like to blend DI & mic'd usually - can't always be done though. |
I'll probably get bashed for this but I've gotten nice results using a POD. My bass player even uses a guitar POD 2.0 version. Used units can be picked up at a reasonable prices. He gets some really great sounds from it...Bass -> POD -> Mixer.
Just a thought.
She's not the boss of me
I have a little cheap Mackie 1202. Each channel has a balanced mic pre and a 1/4" jack that I don't think has any pre. I think I will need a DI box like the fellows above said. Thanks for all your help.
#12
#13
Or go spend a bunch of cash, whatever. |
#14
Plug the bass in and play it. |
#15
K, I'll try it. Thanks.
#16
agree. If you have the bass and the mixer, why not just see what you think before buying anything else
#17
Just like EZ said. You do NOT have to buy any boxes to get the tone you want. All the Pro. studios I played in..,
just plug it in and technique IS everything.
[SIGPIC][/SIGPIC]Instant Karma tried to get me... and succeeded |
#18
another vote: Direct In.
the bass and a cable. Possibly for a amateur, beginner BASS track, a compressor is nice as it tames the "plunkers" down. but tracking is all about performance, so maybe stop the compressor and just learn how to play really well and controlled. you don't need an amp and mic thats for sure....of all the HR stuff, the bass can be done really well direct....much better than 6-string (which will sound like ASS plugged straight in).
if it's not happening in the room, it ain't gonna happen on tape.-HG |
| DI Box the solution? | TripleJ | Newbies | 52 | 09-08-2006 09:52 |
| Input on bass/ amp purchase | bigdaddyd | Guitars and Basses | 3 | 11-10-2004 11:18 |
| aardvark direct pro user.... Advice on recording DI Bass needed | Rassoodocks | Recording Techniques | 13 | 06-24-2003 07:09 |
| aardvark direct pro user.... Advice on recording DI Bass needed | Rassoodocks | Digital Recording & Computers | 3 | 06-21-2003 18:18 |
| Getting good sounds from Bass Pod Pro | luckymann | Guitars and Basses | 3 | 05-06-2003 17:33 |
