Old 04-09-2007
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
FS / FT: M-audio Delta 1010
I would rather find a trade than sell, but I would sell it for the best offer + shipping and paypal fee. I upgraded converters a year ago and never using the 1010, it's up for grabs. I just tested all the I/O and everthing is working great like it did when I bought the unit.
Looking for:
OC 703 or 705
Sm 57's
Senn 421
Mogami TRS 3' patch cables (store bought or homemade)
Please entertain with other trades as well.
Please PM with offers.
thanks, Garrett
Old 04-09-2007
gcapel's Avatar
boom box recordings
Photo's Posted:
Old 04-09-2007
gcapel's Avatar
boom box recordings
Forgot to mention I am on the good guys list!
Old 04-09-2007
noaht noaht is offline
Newbie
noaht is a name known to allnoaht is a name known to allnoaht is a name known to allnoaht is a name known to allnoaht is a name known to allnoaht is a name known to all
What did you upgrade the converters to?
Old 04-09-2007
gcapel's Avatar
boom box recordings
RME Multiface II
Old 04-10-2007
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
I have 2 1010s but I need a backup. If you decide to sell outright I may be interested.
I have a few 57s but I still need them all the time.
Tom
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 04-10-2007
Minion Minion is offline
1K Silver Member
Minion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond repute
I would be interested in the Delta 1010 but I really don"t have much to trade...
Maybe I can build you something that you would take for trade Like maybe a Guitar effects pedal (Overdrive, Compressor) or maybe a Mic preamp or a couple Omni Condencer Mics or a Phantom Power Unit or a DI Box or a 20db Mic Pad?? You would have to wait a week or so to give me time to build what you want and I could possibley add some custom features to the units.....
If yer interested let me know.....
Cheers
M-Audio Delta 44 + Delta 1010LT
5 Piece Drum Kit w6 Cymbals
Custom Made Bass Guitar
Custom Made Les Paul Guitar
Mackie Traction Studio 2.1
P-4 PC w 512mb DDR 80gb HD
Sell you used Equipment Here:
http://www.proaux.com/phpprobid/index.php
Old 04-11-2007
gcapel's Avatar
boom box recordings
Cheers
I'm intrested in this idea. What type of preamp build?
thanks, Garrett
Old 04-11-2007
1K Silver Member
Most of the Preamps I build are Solidstate designs....I just Finnished a 2 ch 1U rack Unit useing a couple of Burr Brown INA217 IC"s useing my own design with a Fully Ballanced Output stage....(these are the same or simular IC"s that are in the DMP3,Dav BG-1, In some Foscurite and Presonus units and some High end Mixing Consoles)
They provide up to 66db of Clean gain Ballanced (or 60db Un-Ballanced) have Input Hot plugging protection extremely Low DC Offset (So Low my equipment can not even measure it) and 48V Phantom power for each Independant Channel and with a THD Lower than 0.007% at 1Khz at 40db gain.....
I have also built Preamps Based on the "Green Pre" (I have a Very ugly 2 ch unit that was my First Build but it sounds very good).....
I can also build Preamps useing Discrete NPN/PNP Transistors for the Input stage and with your choice of output Stage IC"s.....
I could also probably build you something to Your specifications to a certain extent but that would take more time as I have to design and troubleshoot the Curcuit which would take quite a bit of time but I am not that adverce to doing it, as long as it doesn"t require Tubes (I find them hard to work with and just a bit dangerous)....
I am actually working on a curcuit based on the INA217 that I was going to use to Build Single Channel units built into old CD/DVD Drive chassis so they would be small compact and could be stacked together into an OLD PC case, I was thinking after I get a couple built and tested I would maybe start selling them but I need to find an investor to Cough up the Startup money......
Anyways if any of this sounds interesting then let me know and we will see were this will go....
Cheers
Old 04-11-2007
gcapel's Avatar
boom box recordings
Cheers
This one sounds good. Will it have a pad, or 48v option? Could i see some of your work?
I've done stomp box builds in the past, but never got in to the design part. I'm very intrested in your proposition.
thanks, G
Old 04-11-2007
1K Silver Member
Hi...Here is a Pic (a Bad Pic) of the 2 ch unit I just finnished..(It doest have any Graphics or Knobs attached yet)
I do have a Design useing an INA103 IC (simular specs to the INA217 but harder to implement) that has a 20db Pad....
I could add one to the INA217 preamps but would have to redesign the PCB which i was going to do anyways.....
Cheers
Delta 1010 and 1010 ai- adat for 1010 maddrummer Free Ads for Music / Recording Equipment 5 02-08-2004 01:07
Please help compare and define M-Audio 2496 v. Delta 410 v. Delta 44 v. Delta 1010 danielshawn Digital Recording & Computers 6 12-31-2003 02:15
Windows XP & Delta... delphonic Digital Recording & Computers 2 12-06-2003 15:27
ST Audio dsp3000 vs Delta 1010 and the like Chris Fallen Digital Recording & Computers 4 04-07-2003 01:54
PC DAW Digest TAE Digital Recording & Computers 0 11-25-2000 09:03
