Looking For Meter Bridges
Have a Fostex M 80...and of course the meter led's are mostly non functional......(typical) so I'm looking for a couple tascam or similar bridges.....Ebay has squat.....any help would be greatly appreciated......
Hey dgatwood............I havent had it apart yet,but I believe it may be you have to replace the whole led display....they will all work sometimes,and there are dropouts at others.......When I got this unit I was looking for the one with the regular meters because I had heard that the led's were problematic,but the price was right so I got it........
BTW, analog meter bridges aren't a walk in the park, either. The bulbs in those things have a tendency to blow frequently, and if you subject them to an impact, you can throw the calibration off pretty badly. I would lean towards an LED-based meter. Frankly, it's odd that the LEDs would have problems. Normally, LEDs last pretty much forever unless the circuit is designed wrong and subjects them to excessive voltage or current, causing a thermal failure.
Also, on many LED Ladders in Fostex equipment, check them for those notorious cracked solder joints. LED's are hard to kill and cracked joints will probably be what you find
If it doesn't work - scream, curse, cry, and whine profusely. Just don't let the wife see it! |
I'll check the joints.......have to get up the nerve to open it up......Thanks
| bigsbys and roller bridges | kaminari13 | Guitars and Basses | 2 | 11-27-2006 05:40 |
| Why are Bridges not straight | juststartingout | Guitars and Basses | 10 | 04-17-2005 09:50 |
| God Damn Tune-o-Matic Bridges!!!!! Feel free to ignore this post/rant | Light | Guitars and Basses | 17 | 04-29-2004 12:18 |
| submerged wood bridges | mixmkr | Guitars and Basses | 6 | 09-29-2003 15:01 |
| Bass - replacement bridges | montage | Guitars and Basses | 3 | 06-03-2003 15:41 |
