Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 02-15-2001
chaaaaaa chaaaaaa is offline
Newbie
chaaaaaa is on a distinguished road
Hi,
Whenever I use my DOD Death Metal pedal I get serious feedback from my amp. Why?
I play a BC Rich Warlock (Korean)
And I use a Peavey Bandit amp
Thanks
Old 02-15-2001
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
It could be...
...unnecessarily high gain settings...
OR
...overly bright or bad pickups...
OR
...playing too close to the amp at high volume (at loud volumes, you don't need to crank the gain all out...)
OR
..all of the above...
Bruce
Old 02-15-2001
Newbie
Red face Overly bright
Thanks.
What do you mean when you write, "overly bright"?
Old 02-15-2001
Talking
Overly bright, as in "hot" or "trebly" (such as those found on a Tele....)
Bruce
Old 02-15-2001
vox's Avatar
vox vox is offline
Force of Nature
vox is on a distinguished road
Considering that you chose the 'Death Metal pedal' my wild guess would be that you are trying to use too much distorion (gain) in an attempt to get the heaviest sound possible, try backing it down a bit and see if that fixes it. Good luck.
Old 02-15-2001
Tweedville Tweedville is offline
Dedicated Member
Tweedville is on a distinguished road
If your amp is already set for distortion and you crank an overdrive pedal through that,you have too much of a gain stack....the guitar will literally feedback at the volume of a whisper.
Old 02-19-2001
Newbie
So what are you saying Tweedville?
Are you saying I should just use my amp's distortion?
Should turn down my amp's distortion and just use my pedals?
Old 02-19-2001
guhlenn's Avatar
guhlenn guhlenn is offline
Oh REALLY????
guhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond reputeguhlenn has a reputation beyond repute
it's probably the guitar. my friend has got a Warlock (korean) and has the same problem. so i should say it's probably the humbucker. but any other item mentioned by bruce are very likely to be the source...
greetz guhlenn
oh and bruce; gain to almost maximum when played loud or soft (volume wise) is my setting... why do you say the gain can be rolled back when playing louder?
G.
I'll be succesfull tomorrow.
too busy on the forum today...
Old 02-19-2001
guhlenn's Avatar
Oh REALLY????
greetz guhlenn
and i might add that tweedville is more than right : you cannot (as in CANNOT) use both dist. to the max.
G.
Old 02-20-2001
happy hour's Avatar
happy hour happy hour is offline
Senior Member
happy hour is an unknown quantity at this point
Dude, the Death Metal is a feedback crazed beast. Learn to use your guitars volume to control it, or put a volume pedal IN FRONT of the dist pedal.
This beast can be controlled. Trust me, I've been using it for a while and my amp has roughly twice the output of the Bandit. Just takes some practice
Mike W
[white_devil]
Old 02-20-2001
Tom Hicks's Avatar
Tom Hicks Tom Hicks is offline
1K Silver Member
Tom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant future
yes to above-learn gain staging
One of the great secrets of sound managemant is gain staging.Each link in the signal chain can be set to be clean or to color the sound.
It seems you want your main tone to be shaped by the pedal.So you should set up your amp to be at the point of maximum clean volume before any breakup or distortion occurs.Let the additional voltage of the pedal push things over the edge tonally.
Tom
  #12
Old 02-21-2001
As you turn the amp's master volume up, it takes much less gain to get the same level of distortion than it did at a lower volume. If the master level of an amp is at 2 (I know, I know -- who plays an amp at volume 2??? ) and you set your gain to max, for maximum distortion... if you then turn up the master volume to say 6/7 and leave the gain max'd out, the guitar will pretty much howl all by itself... higher volume means less gain is necessary to acheive the same distortion level.
Bruce
  #13
Old 02-21-2001
guhlenn's Avatar
Oh REALLY????
Red face
oohh...
well i knew that... why did i ask then? Well i play metal so uhmmm, i just use maxed out gain... thought it was some recording trick to make the guitar sound better. i guess you're reffering to the tube amp effect here... oh and btw i play at 2-3 most of the time ... tried playing venues louder than 2-3 with a 100watt head-> the sound guy was trying to kill me...
kinda is a bummer to me as i like the distortion that powertubes give me (and a distorting transformer). but i never have heard my head at 10... cuz at 5 the windows start to tremendously move... another victim of the 100watt head race... if i only had been smarter.
ah well,
greetz guhlenn
G.
  #14
Old 02-25-2001
Helmut's Avatar
Helmut Helmut is offline
Senior Member
Helmut is on a distinguished road
:d: Hey Guhlenn, fuck the windows, blow them right out of the building, hehe.
  #15
Old 02-25-2001
Helmut's Avatar
Senior Member
I mean :
  #16
Old 03-01-2001
guhlenn's Avatar
Oh REALLY????
places where i play don't have windows... they are dark and smelly...
greetz guhlenn
G.
