Go Back   Home Recording > General Discussions > Mixing Techniques
Old 03-22-2007
Chris Jahn Chris Jahn is offline
Senior Member
Chris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond reputeChris Jahn has a reputation beyond repute
Thickining up guitars?
I have some guitar tracks that are just a little thin. Now before i get a pile of responces about micing techniques, room sound, and dialing in the amp, let me just say that i dont have the option for these tracks to go back and track them better. Imstuck with what i have for the moment.
So what im asking for is some comp/eq and anything else suggestions for beefing up thin high gain guitars post tracking?
Old 03-22-2007
joswil44 joswil44 is offline
Senior Member
joswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond reputejoswil44 has a reputation beyond repute
If you have a Line 6 POD you could try Re-Amping.
Basically run the guitar track through the input of the POD switched on Re-Amping mode and then you can apply more lows, mids, highs, Gain, etc.
Otherwise its tough, you kinda have to do your best with EQ and maybe compression.
But the reality is garbage in ='s garbage out.
And what ever you do to Polish it up will just be Polished garbage.
Try your best to do what you already know how to make it work or Re-Amp if possible.
Old 03-22-2007
DAS19 DAS19 is offline
Me, You, And Davey Too!
DAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond repute
I would try making two tracks of the same track panning each hard or 50%. Then add the correct compresson for the guitar no one can really tell you how much or how little to use. We can just tell you around where it sohuld be for that instrument but still doesnt mean that at someytime u might not want it differnet.
Use your ears. Play around with the two tracks put differnet effects on the different tracks. Maybe make 2 more of the same track and compress it differently or eq it a lot different.
This is just what I would do.
Dave
Old 03-22-2007
He said they were a little thin not garbage.
Old 03-22-2007
Senior Member
Dave
Sounds like he already said he is not in a position to add more tracks so he doesnt have anything else to double with......
One thing you could try is duplicating the guitar track and then throw a small delay on it, like 10-15 milli seconds.
That should simulate the same inconsistancy's as doubling a guitar track which make it sound thicker or fuller.
Pan it to taste from 75%to 50% and try EQing it a little differently and see if that helps thicken the sound.
Do the same on both sides assuming you have a left and right guitar track.
Old 03-22-2007
Senior Member
The reamping thing? (cuz i do have a line 6 pod) when im runing the guitar
out where is i coming from?, am i running a soloed track of the guitar straigh from the outs on my interface? and then hitting record on another track? it seems like that would do it but it also seems to simple and fraught with danger!!!!
just one line (left or right cuz the track mono through the pod out of the pod onto another track? yes/no kinda?
and the re amping mode switch, im not looking at the line six as we speak, is it in plain site?
Also if im monitering what im getting, and i want to mute the outgoing guitar isnt that gonna stop the signal, what the situation for listening to the resualts, and what about the level of output from the computer, im sure that would effect the sound?
Old 03-22-2007
Senior Member
I am not calling his tracks garbage.
I said the reality is garbage in ='s garbage out.
Its a figure of speach.
Recording Instructors say it all the time.
Implying that the best solution no matter what is to do it again the right way.
Obviously he stated he cant do that, but for future reference it should be remembered and this situation should be avoided.
Old 03-22-2007
Senior Member
dont worry i didnt take it that way. and its not that i dotn have mor tracks to use, im just not in a posistion to re-record the guitars, so i have to work with the tracks that i have, but i have tons of tracks to double triple wahtever and i can also do the reamp thing which i posted many questions about above.
Old 03-22-2007
Senior Member
I believe the POD 2.0 has a small black switch the slides. It might say AIR next to it or something like that. Check the Line 6 website for the manual if you have to. It might be next to the Mono or Left Output jack.
But you basically have it right.
Rought the guitar solo'd through your output and then into the POD. Then the MONO or Left Output of the POD back into your input recording on a new track.
Im not sure how the monitoring will work according to how you have your configuration but Im sure you'll get it working.
Just test it out.
Old 03-22-2007
Senior Member
one last thing i just thought of, why not jsut run the signal through an amp modeling plu-in? is there somthign about this idea that is inferior to running in all the way out through an external device such as the line 6?
Old 03-22-2007
Senior Member
Basically works the same.
It might even produce a better sound with a modeling plugin since your not adding noise or losing signal by re-routing to the Line 6.
But it never hurts to try if you have the Line 6 now.
  #12
Old 03-22-2007
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
beat me to it
"And the light in the tunnel that you're chasing is a train"
-Shooter Jennings
  #13
Old 03-22-2007
Sonixx's Avatar
Sonixx Sonixx is offline
1K Silver Member
Sonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond repute
can you possibly post a short clip of just the raw gtr track?
Clips...
  #14
Old 03-23-2007
xfinsterx's Avatar
xfinsterx xfinsterx is offline
Metal Dork Extraordinaire
xfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond repute
Boost a wide band from80hz to about 150 hz.
Boost till it sounds fat.
Then put a multiband compressor next in line (Like a waves C4 or something of the like) to push the lows down under control. Doing this keeps the lows fat but not out of wack. This typicly works well for me. Youll need to experiment, but its a good possiblilty you can make it work for you with some patience.
Chris Finster
Geomana on myspace!
Falcon Recording Studios
  #15
Old 03-23-2007
Flangerhans's Avatar
Flangerhans Flangerhans is offline
Dodecahedronic member
Flangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond reputeFlangerhans has a reputation beyond repute
If you've got a harmonizer, try a track of that mixed behind the guitar tracks, use an appropriate lower interval for the music, and eq it to fill in the low end. Kind of like an aural exciter for low mids. I've had luck with this before...the double then delay solution is very workable, reference the vocals in the Doors "Love Her Madly" for a use of this technique.
The other method I can think of is to tone down the other tracks, cutting eq in them where the guitars fit, and letting the perceived guitar get thicker in contrast.
Finding a method that is compatible with the type of music you make is a consideration as well. The more distorted the guitar, the better it will respond to eq thickening, whereas clean strings work well with delay effects, at least IMLW.
  #16
Old 03-23-2007
Tim Walker's Avatar
Tim Walker Tim Walker is offline
Junior Member
Tim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond reputeTim Walker has a reputation beyond repute
Thin guitar tracks are garbage.
Tim Walker
365 Songs in 365 Days in 2007
www.trymungous.com
http://myspace.com/timwalkersingsandplays
"Tim Walker Sings And Plays Modern Day Love Songs For Every Occasion" available on compact disc.
  #17
Old 03-23-2007
Myriad_Rocker's Avatar
Myriad_Rocker Myriad_Rocker is offline
Registered Text Offender
Myriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond repute
How in the hell is he going to re-amp the track if it's not a clean track? He already said it's high gain guitars. Re-amping already distorted guitars (unless you're just reamping for pre color) will not work. Unless you like hearing crap.
The best suggestion that has already been given is to employ the Haas effect. This is the copying of one track and shifting the copy by some milliseconds to give that "double tracked" feel.
If you have a nice pre, you could also reamp through that. But not through the Line 6 POD.
  #18
Old 03-23-2007
Reggie's Avatar
Reggie Reggie is offline
PutsTheLotionOnItsSkin
Reggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond repute
Use a parametric equalizer to add fatness and subtract thinness.
  #19
Old 03-23-2007
Jamz0r's Avatar
Jamz0r Jamz0r is offline
Senior Member
Jamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond repute
That's probably the easiest way to correct the problem.
Maybe clone the track and use 2 slightly different EQ settings, and a bit of panning.
Also, make sure you are deciding the guitars are too thin with the entire mix, and not while soloing the guitar tracks. Sometimes people shoot for a killer sound while soloed, but need to consider the entire mix.
  #20
Old 03-23-2007
Senior Member
I think this qustion was sorta answered above, but i was wondering, if by putting a "delay" on a second track of the same guitar it meant a delay effect, or sliding it over a little bit?
Cuz i tried just adding some effect last night, and it actually kinda worked, but in retrospect i think people were suggesting that i shift the track over a bit!!
  #21
Old 03-23-2007
mrhotapples mrhotapples is offline
Dedicated Member
mrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond repute
I like to pan rhythm guitars pretty hard and then send them to a reverb channel mixed in pretty low and about 50% in. Sometimes I'll do the opposite. It sounds good though, it feels more like reverb since the reverb is chillin' out in the back behind the kick and snare and cymbals but the guitars are still wailin' on the sides.
  #22
Old 03-23-2007
Senior Member
I'd stick to actually applying delay on the duplicated track where you specifically tell it how much delay you want.
Theres not much point in moving a track unless your trying to sync something up that already had a delay in it.
  #23
Old 03-23-2007
Senior Member
He can reamp IN HELL and not have to add more gain to it. Its called turning the gain knob down.
Besides, the Modern "High Gain" setting on the POD has much less gain than the Rectifier Setting.
High Gain to a Van Halen fan is differnt to High Gain of a Cannibal Corpse fan.
Its all up to him to figure out using all of the possible solutions we can give him.
Whats the point in shooting down other peoples ideas when you havent even thought it through yourself.
  #24
Old 03-23-2007
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Am I the only one flabbergassed that we're (as of this writing) some 30 hours and 24 posts into this thread and nobody has asked what Chris' definition of "thin" actually is or asked to hear a clip so that they can actually hear what he's talking about?
One man's "thin" is another man's "flabby".
EDIT: Correction. Sonixx actually asked for a clip early on. Smart man
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
  #25
Old 03-23-2007
Sonixx's Avatar
1K Silver Member
this is not that good of a solution. you'll find that in some spots the image collapses.
Reggie has the answer...
2nd and last try... will you post a short clip?
Clips...
Bookmarks
Tradition Guitars--Samick?? battleminnow Guitars and Basses 13 03-04-2008 07:35
Bob Taylor's approach to making guitars dobro Guitars and Basses 19 10-15-2005 22:19
Whe good companies go bad!!!!!! Light Guitars and Basses 26 03-25-2004 12:04
panning guitars in mix gjb3 Mixing Techniques 9 04-28-2002 00:07
Paul Reed Smith guitars Hard2Hear Guitars and Basses 39 06-23-2001 20:38
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1995-2010 Audiofanzine except where noted. All Rights Reserved.
