Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 02-14-2001
Major Tom's Avatar
Major Tom Major Tom is offline
Dedicated Member
Major Tom is on a distinguished road
Unhappy
I have a Fender Performer guitar(similiar to strat, Japanese made from mid 80's). The high E string sounds weak; both acoustically and amplified. It has way less sustain and power than the other strings. I use 10-46 gauge strings. I've tightened the neck screws, tried changing string height, tried adjusting the Trem spring tension, removed and remounted the bridge saddle, the truss rod seems to be adjusted O.K. I have noticed similiar results on other guitars that I have played and own, but not to this degree. Any suggestions ??
Old 02-14-2001
Treeline's Avatar
Treeline Treeline is offline
Don't Give Him Coffee
Treeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond repute
Adjustable pole pieces on the pickups?
Try letting out the screws on the center pickup first, 1/8 turn, just under the e-string and see what happens. Mark them before you fool with anything so that you can return them to their prior settings if you need.
You might also have a nut with too deep a slot cut for the e-string; grabbing it instead of letting it rest over a break point. There are ways to address it, but you might want to take it to somebody for that. It can be built up with superglue and recut, but it's a real mess if it gets away from you.
Old 02-14-2001
Major Tom's Avatar
Dedicated Member
This guitar has 2 pickups, non standard, splittable humbuckers, blade magnets I think...they are not accessible. Also, I forgot to mention B-4, I have the pickups low enough so that magnetism is not a factor.
Old 02-14-2001
Tom Hicks's Avatar
Tom Hicks Tom Hicks is offline
1K Silver Member
Tom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant future
crash and burn baby
guitars are like people as to their individual voices.If it won't sing its firewood.Don't be like the guy hanging on to the girl who dumped him.There are too many good axes out there waiting for your hands to make them speak.
Look at it this way,many guys wouldn't even notice the flaw.The pickier you get the better axe you want to play.
Tom
Old 02-20-2001
peter miller's Avatar
peter miller peter miller is offline
Force of Nature
peter miller is on a distinguished road
Cool
I had that problem once and brought the pickups closer to the strings and whamo-Tone!!!!
Old 02-20-2001
Tom Hicks's Avatar
1K Silver Member
I had originally thought the string was out of line with the pole piece of the pickup,but you suggest it has a blade style pickup,which wouldn't be a problem with allignment so much.
Tom
Old 02-20-2001
vox's Avatar
vox vox is offline
Force of Nature
vox is on a distinguished road
I am not familiar with you guitar model, but a lot of less expensive guitars come with tuning pegs and bridge saddles which can kill your tone, if either of these are really light and flimsy maybe, MAYBE, changing them would fix the problem.
Old 02-20-2001
Treeline's Avatar
If the pickup blade is too far away from the strings, then magnetism IS the problem. The high e string is the lightest gauge of any string; it has the least mass and will generate the least powerful magnetic field. Moving the pole pieces - or the blade - further away will make the signal weaker. Find a way to move it closer to the string. The magnetic field within which the string vibrates will be inherently stronger. Make that sucker LOUD. Now you should have a signal that can be worked with.
Old 02-23-2001
Major Tom's Avatar
Dedicated Member
Thanks for the advice. One problem I did find was nut related, the nut was being shoved out of it's slot on the high E side, I guess from sweat, humidity or whatever, I fixed that, and the string sounds much better in the open position, hovever it is still weak in the "mix" when fretted. I tried raising the pickups but they will not come up a whole lot, I will have to take it apart and maybe put some longer springs in to get it up significantly closer. This is one of my secondary guitars, and the problem is not bad enough to turn it into firewood, but Tom Hicks does have a good point! Sound like a good excuse to head to the music store and look at some new axes!
Old 02-24-2001
Treeline's Avatar
Talking
Hey, any port in a storm!!
