Which reels to buy?
Hi all, and Greetings from Hamilton, Ontario. I am new to the forum, and have been away from Reel to Reel recording for about 20 years or so. I've just begun building a retro system and am going to be recording all of my old albums.
When I was recording years ago, I was using only the Maxell Ud reels. That's because that was all that was available where I was living at the time. Now, of course there's this thing called the internet, and I've discovered that there is more than Maxell. I am looking at some basF 468 , some Quantegy 480's and finally some 3m 908's. I was familiar with none of these tapes, but they've apparently been recorded on once. Can anyone tell me which is the best tape to use of these, or am I better to go back to the old familiar Maxells, never recorded on ? Thanks in advance for your help !!! |
Which machine are you recording to and are you aware that you will need to rebias it for the type of tape you will be using ?
Maxell tapes are great but there are newer and better formulations still made today, namely ones from RMGI (same stuff as BASF / EMTEC). |
tape deck
Hi and thank you for your response.
I'm not quite sure of what you mean by re-biasing the machine. I've just bought an older Pioneer t-6600. however, that is probably going to be a temporary move until I can afford a Tascam or Revox. What is meant by rebiasing? Thanks |
http://hyperphysics.phy-astr.gsu.edu...udio/bias.html http://www.answers.com/topic/tape-bias After reading the above, you'll understand why it is neccessary to set the correct "bias" for different tapes outthere. You cannot just pop whatever tape on a recorder and hope for the best. If your machine was biased and setup for Maxell UD tape then you will need to adjust bias for another type of tape if you want your recordings to sound faithful to the original. (There's a whole thing on electronic and mechanical alignment but lets leave that alone for now). I suspect on your Pioneer it may be a difficult proposition as the bias may not be sufficient for more modern tapes. Of course, I don't know this for sure as I'm not intimately familiar with your model. You may want to stick with the Maxell till you get one of the other recorders. |
Quantegy 480's (and 478's) are "spec'd for Nagras and superior performance", which I've looked at the spec cards (not in front of me at this time), and it looks like you can run it about +3db hotter than "four five six". Again, pls don't flame me!! I gotta correct this now, after a quick check of the spec/list: 3M 908 is a is "made-to-be compatible with Quantegy 480" tape, so in the turnaround [estimate] that "908" is run "+3db hotter than 456". Pls dont,... aaaagggghhhh!!! That's all I gotta say,... 'cept: Aw, fuck! Flame away! ![]()
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
Be careful with 3M Scotch tapes, they're sticky! Basf (or RMGI) and Maxell would be your best choice
http://homerecording.com/bbs/showthread.php?t=145211
http://homerecording.com/bbs/showthread.php?t=148809 You gotta learn 'specmanship' to read these papers, I'll forewarn you. You can thank me later. ![]()
setting bias
So how does one set the bias on a tape machine to meet tape requirements? Is it a mechanical adjustment?
Thanks. |
| Beware: Fake Reels On Ebay | Beck | Analog Only | 4 | 03-02-2007 21:35 |
| Advise to buy a guitar amp!!! | jmgrosso | Guitars and Basses | 13 | 07-07-2004 12:50 |
| 400$ to spend What to buy | jskillz89 | Other Equipment and Reviews | 6 | 11-25-2003 11:03 |
| I got 5 tracks 4 Drums - what mics 2 Buy | MercyfullMusic | Microphones | 8 | 04-17-2002 22:40 |
| A story about what to buy | Chris Fallen | Digital Recording & Computers | 36 | 03-27-2002 15:14 |
