Old 03-19-2007
CIRO's Avatar
CIRO CIRO is offline
Capituīs brother
CIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond repute
DMP3īs low cut
I bought a DMP3 yesterday.
Ok, itīs a clean, good pre amp, as everybody knows, but...
I would like to know, by others owners :am I crazy, or the "75 hz low cut" sucks?
I have the impression that when the LC button is pressed, something kinda "out of phase" happens (well, at least my MXL 2003 mic has a good low cut ..)
Thanks
Ciro
Old 03-19-2007
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
Yeah, I've noticed that, too. The low cut on the DMP3 really degrades the sound. I never use it. I work on mic position first and do any other EQ at mixdown.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 03-19-2007
mrT's Avatar
mrT mrT is offline
Force of Nature
mrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond repute
then leave it off and use a plug-in instead...
Dishonest lifelong misspeller and theif...
Graphic
When Your Horse Dies, Get off It...
-David Petrie's tomb stone.
Old 03-19-2007
danny.guitar
Guest
Posts: n/a
I didn't notice it. I've only tried it once or twice. I didn't notice any "degradation" in the sound. I did notice, that everything below 75Hz was cut off though
Just get mic placement right and EQ if you need to afterwards if you feel it's messing with your sound.
Old 03-19-2007
Doug H's Avatar
Doug H Doug H is offline
I'll be there
Doug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond reputeDoug H has a reputation beyond repute
I tried it a couple of times and have never really been tepted to use it. I couldn't say it sucks, I don't really know any better, but for what it's worth, I never use it.
Old 03-19-2007
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
It does seem to shift the phase.
She's not the boss of me
Old 03-20-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
Noticed the same thing. Love that preamp otherwise, but the low-cut seems to cut a LOT more than the low cut on my Yamaha board. Not sure what the problem is, but I don't use it as a result... removes too much from the signal.
Originally Posted by Ford Van
I AM RIGHT
Old 03-20-2007
producerkid producerkid is offline
You're all insane...
producerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond reputeproducerkid has a reputation beyond repute
NOTE: If you are monitoring directly off the pre through headphones, etc and if you are playing the source instrument (singing, acoustic guitar, whatever) yourself while engaging/disengaging the low cut, the phasiness your hearing is most likely an illusion caused by hearing the full low end of the instrument itself then hearing it with the low end cut out through your cans. Makes sense? No, i didnt think so.
Heres a good trick to find out whats really going on: record a dry track of whatever, prefferably something with a wide range (acoustic guitar is great for this), then feed it back into the DMP3 and listen to it while engaging/disengaging the low cut switch. ONLY MONITOR THE SIGNAL COMING OUT OF THE PRE AND NOT THE PRE-RECORDED SIGNAL COMBINED WITH THE DMP3 SIGNAL! If you are still hearing something wierd, then the low cut circuit is most likely the culprit, if not then all you were hearing is the instruments' low end vs. the lack of low end of the shelved signal.
Pheww i hope that makes sense. lol
Also keep in mind that cheaper gear is cheaper because someone cut a corner somewhere...point blank. Phase incoherencies happen anytime you put something in the signal chain. Phase (in a nutshell) is basicly a very small amount of time or delay between one signal or another, or between the source and the output. I've noticed that some cheaper gear actually uses more bullshit in the circuit than is necassary to achieve a desired result rather than using the equivelant one or two parts because the parts are expensive. However, every component you add in a circuit is just one more part the signal has to pass through before it reaches the output, thus causing some phase problems.
IMHO, phase can somewhat be compared to latency in the digital realm in a sense that the more gear you have in a chain, the more out-of-phase your end result will be (be it a very small difference).
Anyways, if there ARE problems in the low cut circuit of the DMP3, its probably phase-related, and id be willing to bet its because of poor design and was a quick afterthought to the design of the preamp. Not a real big deal, but something that is worth noting.
Someone shoot me for babbling and correct me if im wrong please, i hate sounding like and idiot. lol Hope some of my ramble helped.
the kid
Simul-Sync (no autographs please, ha)
Old 03-23-2007
junplugged's Avatar
junplugged junplugged is offline
Busy Writing/Producing...
junplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond repute
i'll use the same kind of mic one on each channel one w/ lo cut one w/out. i always just use it so thanks for the heads up, i never considered not!
Old 03-24-2007
Halion's Avatar
Halion Halion is offline
1K Silver Member
Halion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond repute
Yes, it really does seem to affect the signal more than just cutting the lows. I don't like it and therefor, won't use it.
size of CR window cmick Studio Building & Display 7 04-12-2007 02:20
the Basics fuquam Mixing / Mastering 26 02-26-2007 18:45
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
I cut an event exactly in half based on sample rate, but it's not exactly halved,wtf? MistaMash'dup Cubase User Forum 3 02-11-2005 10:16
Wood, and hardware?(Production desk materials) Voxpopuli Studio Building & Display 10 01-30-2004 21:18
Copyright Đ 1995-2008 Audiofanzine except where noted. All Rights Reserved.
