Old 03-19-2007
Vadim Vadim is offline
Senior Member
Vadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond reputeVadim has a reputation beyond repute
fixing/cleaning crackling/non-working faders in mixer ?
I have a mixer Mackie 1604 VLZ-pro, the MAIN MIX fader has only one "R" chanel going thru. and Sub fader "3" sometimes works, sometimes doesn't...
anyone know best way to clean them or something, or just replace them?
Old 03-20-2007
kessel's Avatar
kessel kessel is offline
The Dancin Outlaw
kessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond reputekessel has a reputation beyond repute
Probably best to just replace them if they are that bad.
"I put the butcher knife up to her neck and said if you wanna live to see tomorrow, you're gonna start fryin' 'em eggs a little better'n what'chu been fryin' 'em. I'm tired of eatin' sloppy, slimy eggs!"
- Jesco White
Old 03-20-2007
ez_willis's Avatar
ez_willis ez_willis is online now
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Definitely BEST to replace it, but if it were me, I'd try cleaning it first with a product like DeoxiT.
Old 03-20-2007
Senior Member
it might not even be the faders,
I also noticed that connectors/sockets are a little rusty,
and when I connected/disconnected a cable to main Insert, the MainMix started working,
than the Right channel got lost, than i moved the fader all the way up and down and it started working for a while.
also i have EQ connected to MainInsert, and when the right channels drops out, the EQ seems to be not effected, still both channels getting signal...
maybe it's circuitry after the faders?
Old 03-20-2007
amzavareei amzavareei is offline
Senior Member
amzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond reputeamzavareei has a reputation beyond repute
You can get deoxit and contact cleaner at radio shack. The spray can with the nozzle is cheaper. Blast the little hole on the pot(on the inside) or down in the slider hole, and twist or slide a few times. Works great! Blast the conectors too, then insert plug and remove several times. Lube that #$%# up! It's also possible a jumper cable is loose. I got a free amp that way! It was intermittent, and it was just a loose cable!
Old 03-20-2007
TragikRemix's Avatar
TragikRemix TragikRemix is offline
I am NOT a Gear Whore. ;)
TragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond repute
make sure you dont have a busted cable first.
GFCG Member: 000 029
F**k Your Scene.
Old 03-20-2007
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
De-oxit in the can. Get it.
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
Old 03-20-2007
tnjazz tnjazz is offline
Force of Nature
tnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond reputetnjazz has a reputation beyond repute
There are many different flavors of De-Oxit, so be warned. I opted for the Gold, it was only about $6 more than the others and it seems to be the most "all purpose" of the bunch...
Old 03-23-2007
Senior Member
I went to radioshack, the closest thing they had was: "Control/Contact Cleaner & Lubricant" on bottle it says: For electro-mechanical devices-especialy drum-type TV tuners. Reduces wear. Safe on most plastics.
is this ok to spray inside the 1/4 sockets in the mixer?
Old 03-23-2007
MOFO Pro MOFO Pro is offline
Opinions are like SM-57s
MOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond repute
It is... It's the exact same thing... only different
It's fine really... contact cleaner is contact cleaner... some are just better than others... you won't do any damage
I will suggest that you unplug the unit before you do... be conservative with your spraying, and then work a plug in and out of the socket...
Old 03-23-2007
Lt. Bob's Avatar
Lt. Bob Lt. Bob is offline
Spread the Daf!
Lt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond repute
Right .... but Craig Deoxit is the best by a pretty large margin. RatShack definitely has it .... I bought a combo pak with one can of deoxit and one of deoxit gold from them just the other day. The regular deoxit is best for cleaning ..... the gold is more for protecting it after cleaning.
  #12
Old 03-23-2007
Agreed...........................
whats the advantage of a non digital mixer when working with digital software? wallsstreet Recording Techniques 6 11-20-2004 05:43
I need a roadmap for my new mixer! Help Wireneck Other Equipment and Reviews 6 11-18-2004 05:48
Mixing board analogy for beginners. SPINSTERWUN DJ & Hip Hop Production 4 10-28-2003 18:33
How to record an audio track and what is the big advantage? rdeboer Cubase User Forum 15 10-10-2000 21:08
The use of mixer for computer recording??? jelly Digital Recording & Computers 6 07-06-2000 04:06
