upgrade audio interface & puter???
Hello Homerecorders,
I need to be able to record one (maybe two) channel(s) at 44.1 khz/16 bit with no latency issues, pops, or clicks and my current setup is not working, despite messing with the settings ( I think it is due to a weak computer with USB 1). I am thinking firewire will solve this??? I will am willing to save for quality equipment (mid price range), but obviously I shouldn't have to spend $$$$ for a simple setup-- let me know if all I need is a new interface/firewire or if I should save for a new computer and a new interface??? Or maybe I should try a different setup??? Thanks for any suggestions, Chad Current setup: dell laptop 1.6 core duo, 512rm Win XP Media Center Edition, M-Audio Fast Track Pro Sound Forge 4.5, Acid pro 2.0 |
myspace |
I'll double check the settings and keep working with it-- do you have any latency issues? Right now, when I record eack track, I have to manually line them up in time by editing them, but I was hoping to not have to do this. Thank you, Chad |
I'd say settings also... The computer must have USB 2, might not
be a bad idea to upgrade to USB 2 or firewire... but at this point it probably won't resolve you problem... You've got plenty of horepower there |
I cant explain in detail, but from what I've heard and read I would suspect that "Media Center" is a big part of the problem. I saw a guy running a full Nuendo setup doing 64 tracks on a machine with less msucle than what you have..... his secret is running a stripped down version of Windows, no internet, no email, no junk.....and believe me, Windows will run a boatload of junk behind the scenes if you let it, especially Media Center, which is intended to replace your entertainment center....
Just think how good you could play if you were sober! My Little Corner Of The World SC's MySpace |
I am running a PIII computer with 512, and get 20 tracks with no problem over usb 1. You should be fine without the MC OS.
Tom |
much appreciated
Hey guys,
Thank you so much for all your help-- I will look into getting a different OS or maybe learn how to disable media center-- I have finally found the problem!!!! Keep on recording, Chad |
go to control pannel/ add remove programs and seriously delete or disable any program that you don't use. disable outlook express, any programs that may start up automatically on your taskbar. if you have itunes/ or anything else that you want to keep but starts up automatically or stays on your taskbar then disable that feature. run a spyware search and delete any spyware that could be slowing you down. ive temporarily been using a 1.4 ghz celeron with only 256 mb ram and i can record as many tracks as i want without a hitch. but my brother has a 2ghz laptop with 512 ram and it goes 1/10th the speed of mine because of all the useless crap he has that runs in the background half of which i doubt he even knows what is.
i apologize if i've treated you too much like someone who doesn't know anything about computers if you've already done all of this. |
Update...I think it is fixed!!!!!!!!!!!!!!!
Hi everyone,
Thanks for all the help. I haven't had time to fully test it, but it looks like but disabling the wireless internet did the trick! I did a quick session of vocal tracks with no clicks/pops during playback ![]() |
On the latency issue, make sure to use hardware monitoring.
#12
Hey CBSC,
Think about recording with NO latency by NOT MONITORING your source while tracking... What I mean is listen to the bed tracks through the computer -> through a head phone amp and then also pump your line in directly to the headphone amp too. You will lose the ability to apply effects for the headphones, but you can completely eliminate any latency issues by not having your source run in - then out - of you computer while tracking. Hope this makes sense. I know it will work. Jim |
#13
| Can the POD XT Live be used as an audio interface? | darkecho | Digital Recording & Computers | 5 | 11-29-2006 12:18 |
| My Review of the Behringer FCA202 audio interface | jndietz | Digital Recording & Computers | 21 | 05-30-2006 11:43 |
| Audio Interface Upgrade | illsteele | Recording Techniques | 2 | 03-19-2006 01:43 |
| Audio interface and Home Studio 2002 | NikLEye | Cakewalk / Sonar Forum | 3 | 12-31-2002 12:37 |
| Audio Interface via firewire = latency? ::: | Badtz | Digital Recording & Computers | 2 | 05-22-2002 22:26 |
