in need of major help!!!
everytime i get pain-stakingly close to being "finished" with a project - something nearly catastrophic goes wrong -
was just doin a post about my new project finally bein finished and now the computer's drive wehre i placed all the files is DEAD - hopefully there is a computer guru somewhere who can at least retrieve the files - anyone got any know how bout this? |
not to worry G, ther are a lotta software for file recovery. try gettin some of those on download or search for it. it can recover files dat u thot u ll never will.. hope it goes okay wit you.. u already know it, then sorry man. i d also suggest fo a computer guru. peace.
Is the drive dead? Meaning no power and not moving? Then you need to go to a certified computer repair center. They can recover your data for you. But, the draw back is will cost you. It might be worth it saving you time.
If the drive if working, like said you can use a disk utility to fix and repair the dive. if you used Norton file saver, it would be even easier to find your files. Files are not really deleted (unless you do a re-format) form the drive. Small data and bites are there. You just have to rebuild the files. What may have happened is the resource fork which helps the drive locate and point to files got corrupted. The files are still there, but the computer can't find them. It's like your computer lost the map to locations and it's just running around looking for it. Use a disk utility to fix that problem. BUT DO NOT REFORMAT! A good rule is to backup your sessions every weekend...
http://www.beatsbuy.com/links/banners/reason-studio.jpg "Wax" WORDS TO LIVE BY: "Stay humble! Because fame and money comes and goes, but true family is always there." Producer Resources: http://www.beatsbuy.com http://forum.beatsbuy.com |
oh man.. i'm having a bad weekend too.. my windows install is corrupted. I can't find my os disk... left it in my bro's pc when i was trying to restore his registry. What a weekend.... I would first check to make sure all cables are not loose with the power off of course.... If the drive is not spinning... then it's dead.... I've heard of recovery services.. too, but they are expensive. I have separate drives for everything on my system.. so even thou my os is corrupted i'm not losing anything. I was able to get windows to run cripped... for right now.. but i've got to do a fresh install for sure.. I hate re-installing everything... seems to be a common thing with windows... I swear about 1-2 a year i have to rebuild my system. I do also make backups of all my stuff i really want to keep on dvds and cd's so that if a lose a drive it's not so big of a deal... Demi |
I used to use a hard drive copy machine thing. It was extremely slow, probably spinning at 1K if even. Might want to put another hard drive in there, install a OS, and recover the data using any of those data recovery programs. Anyways, if you have a thumb drive, you can put an OS on there and boot up to it, and access your data that way. What does it do when you boot up? blue screen of death? does it see your hd at all? or is it truely dead and not powering up. Did you check your power supply?
VOTE MMG @ 2010 SOUTHERN ENT. AWARDS NOW EASIER BY VISITING MMG VOTING SITE Check our Myspace! |
if its spinning and clicking then you have bad sectors on the hard drive and you can use one of the Hard drive recovery programs..or take it to a shop...if its not accessing..make sure you didnt change anything in your bio's..shut down and restart the computer to see if it get pick up when restart..if not something is going on..
do your remeber what you did prior to it goin dead> lest start from there..
B Knot 4 bars is hip hop, no need for more if it's a hit!! "Trunks poppin'... B Knot Hits..." Boss Recordings http://www.unsigned.com/bossrecordings http://www.isound.com/boss_recordings http://www.jamwave.com/bossrecordings |
Unfortunately my last known configuration is corrupted as well.. that's how i was running cripped. I could get into the machine, but only by selecting that from the boot menu. Windows sucks... it truely does... You really have to have a backup plan in progress when using it. There is always a chance of you turning the power on and getting absolutely nothing... Instead of them coming out with newer prettier versions. I really wish they would fix the code causing all the problems. They are only adding to the mess with the new graphics engine. The only time they have addressed any real code problems was the move to NTFS.. and even it has problems still.. This is totally off topic.. i was surprised to learn that if you have protools material on a hard drive that you can not use any defrag utilities on it. That's so not right... over time the system cache creates a huge mess of all the data stored on the drive. Demi |
The price of an external hard drive is so minimal when it comes to things like this. I picked up a 250GB external for my music projects, only. I never have to worry about losing that data now.
http://www.changehiphop.com/images/pics/Signature.jpg Preview of the new Album here!!! Mixing and Mastering services for your project, contact change@changehiphop.com |
If you get a unmountable boot drive error on the blue screen of death, pop in your OS, and run Repair. At the command prompt, go \winnt or windows\system32\config and then rename system.alt to systemalt.old and also rename system to system.old. to rename, just at the command prompt type in
rename system.alt systemalt.old <enter>
I would suggest that as an absolute last result.
#12
The first one lets you repair in command prompt, the second one basically over rights everything windows. Then there's the other options, like formatting, partitioning, etc that wipes everything out and reinstalls if you choose to. When pressing the first R (repair) using a OS, it'll ask you if you want to do some emergancy repair where it auto repairs (w2k/nt) or go to command prompt. In WXP, it asks you to repair using the Recovery Console, which you would manually fix things. Wiping the hard drive is the last thing you want to do. If the windows is corrupted popping in the disc and doing those things would work on certain screens, I'll say about 80% of the time. If it doesn't work, it doesn't work, you'll just receive the same errors as before. the System.alt & system files are special. Once you delete them, they are remade again by windows. These files have the start up information and other junk in it. when you rename it, you preserve a backup if in any case you would need it (which is basically never), instead of typing del system.alt... Anyways, windows xp & 2K have the startup info to get windows running profile saved in there. once they are "missing" the operating system itself replaces them with the same exact file, but newly generated in the original first windows installation. I forgot, you could also type bootcfg to fix any boot.ini errors causing start up not to see the os install. I have to do this maybe 10-20 times weekly for different users. not to mention the countless other little problems that these users have.
#13
You can't make these types of changes inside the os... it's attributes are usually set to hidden and read only. That's why they built in the repair console into the setup disk. If you run the repair console you can turn off the attributes of the files: cd c:\windows (changes directory to Windows) attrib user.dat -h -r (makes file not hidden/restricted) attrib system.dat -h -r (same) cd c:\backup (changes directory to your backup dir) copy user.dat c:\windows (copy file to backup folder) copy system.dat c:\windows (same) copy win.ini c:\windows (same) copy system.ini c:\windows (same) cd c:\windows (changes directory to Windows) attrib user.dat +h +r (gives attributes back to file) attrib system.dat +h +r (same) I need to get back into making ghost dvd's. norton ghost really does work.. it's just getting a good backup the first time with it.. is a pain in the butt. Ghost allows you to copy the whole hard drive and all it's contents. Then when something happens you just reimage the drive with your ghost copy. Demi |
#14
There are 3 ways to restore your registry in xp. Either the windows based restore tool located under the accessories/system folder or manually inside the recovery console on the windows cd. The other way is to boot into the cd select repair.. which overwrites the registry and puts the machine back the way it was when you first installed windows. So it's like starting over... but with all your apps still installed.. all dirty...
I personally just wipe my drives... fdisk them... this creates a new boot strap... cause not even those stupid utilities will fix your boot strap if it's damaged. That is the sector located first on the drive.. Demi |
#15
And then another thing Quote:
The reinstallation of windows doesn't overwrites the registry. It reinstalls & re registers .dll files or sort, using the same registry. Anyways, what is the problem with your computer Gully. Is it showing any visual errors? Any noise from the hard drive? Power supply still feeding power? how old is the HD. More information is needed to properly troubleshoot problems
#16
md tmp copy c:\windows\system32\config\system c:\windows\tmp\system.bak copy c:\windows\system32\config\software c:\windows\tmp\software.bak copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak copy c:\windows\system32\config\security c:\windows\tmp\security.bak copy c:\windows\system32\config\default c:\windows\tmp\default.bak delete c:\windows\system32\config\system delete c:\windows\system32\config\software delete c:\windows\system32\config\sam delete c:\windows\system32\config\security delete c:\windows\system32\config\default copy c:\windows\repair\system c:\windows\system32\config\system copy c:\windows\repair\software c:\windows\system32\config\software copy c:\windows\repair\sam c:\windows\system32\config\sam copy c:\windows\repair\security c:\windows\system32\config\security copy c:\windows\repair\default c:\windows\system32\config\default Within the repair console all the retrictions are not active so you don't have to do the attrib removal. If you want to backup the registry outside of windows you can use those commands from the F8 start into command prompt in safe mode. Also using the repair selection from the cd does too overwrite the registry along with the dll's. Here's MS spin...: http://support.microsoft.com/kb/312369/ Demi Last edited by dnkygirl; 03-19-2007 at 09:34.. |
#17
Gully you can also do backups to usb flash drives they are really cheap now.
http://www.tigerdirect.com/applicati...sp?CatId=1995& Demi |
#18
I'm a IT tech too lol @ Solvay Engineered Polymers.
Usually when reinstalling windows on the top of the original windows, it'll still use the same registry key (of course the most recent back up made already). It doesn't actually go in and repair the registry. It takes the copy of the registry from a previous 'working' state from a check point or a backup previously made and replaces the one currently there now. If the original (or backed up registry) was previously corrupted, and the backups are corrupted, than reinstallation does nothing except overwrites like we stated (if it gives you the repair option). http://support.microsoft.com/kb/307545/ http://support.microsoft.com/kb/322756 But regardless, I think it would be wise if we knew exactly the condition of the drive, and what exactly was going wrong with it. For all we know this could be hardware related, or the other way around. http://support.microsoft.com/kb/315341/ Quote:
With those, you can back up, or you can run a OS on it, or make it bootable along with fixes you could use.
#19
Well damn... $40 bucks for 4gb at tiger?? hmmmmm not bad. I think Fry's had the kingston 4GB stick for $50 or some crap.
#20
#21
#22
It's ALWAYS good, ALWAYS good, ALWAYS good to have a redundant backup going on. I'm a firm believe in CYA (Cover Your Ass). RAID set up, 300GB external archive, a couple usb drives, and back ups in different locations (PGT & Weatherman has weekly full backups on HD, and 1 on disc and 1 on a server wherever godaddy is located at lol.
#23
Kewl a fellow geekster... ) I work for Crash Rescue Equipment Service, Inc.Demi |
#24
If the client wants more assurance, then they have to pay for it.
#25
Demi |
