Old 03-16-2007
Wireneck's Avatar
Wireneck Wireneck is offline
Fretboard Acrobat
Wireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond repute
Digi 001 questions
I have been recording on 24 tracks of Adat with all outboard gear for a few years now. In the past 3 years I have setup a small DAW running Adobe audition with an EMU soundcard but I only have 2 inputs in this setup. It is cool for doing overdubs/laying down track ideas but the limited track input makes it where I have to track to adat and then transfer to my Daw. My soundcard doesn't have a lightpipe input so I have to transfer each track one by one and then re allign them manually off the click. It is extremely time consuming.
I have recently been searching for an option to get my track inputs up on my daw. I don't want to spend more than $400.00 and I don't need preamps since I have a big outboard console. I would like at least 16 inputs but more than likely I wouldn't be using more than 10-11 at a time. I was considering picking up a used Digi 001 but I have a few questions.
When using the Adat lightpipe input, can you use the other 8 analog inputs at the same time? So in theory, could I use the first 8 analog inputs and then use an Adat as an A/D to get 8 more channels into the software? I know the Digi 001's usually come with Pro Tools Le, will they function with normal pro tools software?
I am using a PC have there been any major compatibility complaints? I know the DIGI 001 is old but it is newer than my Adats that I am currently running. Any other options will be considered. Thanks for the info in advance.
Old 03-16-2007
sdelsolray sdelsolray is offline
Force of Nature
sdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond repute
The Digi001 can handle 18 simultaneous inputs, 8 analog, 8 ADAT and 2 SPDIF. It is a discontinued product and the last PTLE version that will work with it is 6.4. It has a PCI card along with the breakout box.
I've used a Digi001 for 6+ years, and still do. I bypassed the preamps and converters with outboard gear.
Old 03-16-2007
Wireneck's Avatar
Fretboard Acrobat
In the Le software, how many tracks are supported? Also, what types of plugins can you use?
Old 03-16-2007
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
32
Plugins are RTAS or Audiosuite (but you can get the VST-RTAS wrapper from Fxpansion to use VST plugs)
there may be issues running on newer PCs. I know XP SP2 wasn't 100% compatible with Pro Tools. But there should be a patch for it around the internet somewhere.
www.redlabaudio.com
Computer Can't Find My Digi 001 (XP) sirpunkly Digital Recording & Computers 5 07-14-2005 11:21
What's the best way to run a Digi 001 through a Patchbay? Jburn34 Digital Recording & Computers 1 05-25-2003 18:48
Digi 001 or not? Jburn34 Digital Recording & Computers 7 05-21-2003 06:16
Digi 001, Digimax LT, Focusrite , more XHipHop Free Ads for Music / Recording Equipment 0 04-15-2003 11:02
digi 001: Better for Mac or PC? furiouS Newbies 2 09-01-2001 11:25
