What does "Class 2" Transformer/Power Supply mean?...
...I'm in need of replacing a power source for one of my rack mounted CD players, and the original power supply was rated "12volt 2.5amp/Class 2 Transformer"...I find that there are many replacement power supplies available with 12v/2.5a, but none say "Class 2" on the specs...does anyone know what the Class 2 specification means?...I googled it with no luck...thanks!
reggae souljah |
A Class II transformer is inherently limited to not more than 60 watts. It is a low energy device and considered intrinsically safe. Secondary wiring from a Class II transformer does not require conduit and clamp wiring techniques..." from here: http://www.waclighting.com/data/faq/...ton_lights.pdf All commercial power supplies that you would be using for the device would be class II. You don't have to worry if it passed UL and it is rated for 60 Watts or less. Google search done! Peace
"Tascam, Fostex or Studers don't make hit records...........people do" MCI2424 - 2007 |
...so then I can assume that any 12v/2.5a (or higher amperage) power supply, like those commonly used for LCD monitors would be safe to use?...sounds good...thanks for the clarification..
reggae souljah |
you might want to check to be sure it IS a DC and not AC adapter... given the amperage it could well be AC...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
reggae souljah |
| Silly question about Power Supply for keyboard... | Badtz | Keyboards and Sound Modules | 8 | 08-10-2006 14:27 |
| Question about power supply for my DD-20 | JuicyDbase | Guitars and Basses | 6 | 06-21-2006 15:13 |
| All the World's Tube Microphones PART ONE | Bambi Busboom | Microphones | 2 | 08-15-2004 04:02 |
| Dual separated power supply... | James Argo | Digital Recording & Computers | 9 | 06-09-2003 05:07 |
| The dangers of a bad power supply... | Slackmaster2K | Digital Recording & Computers | 12 | 11-05-2002 16:27 |
