Old 03-14-2007
Gnash5150's Avatar
Gnash5150 Gnash5150 is offline
Lefty
Gnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these partsGnash5150 is infamous around these parts
Peavey SP2 bi-amp
Kinda off topic, sorry. I have a pair of sp2s. I want to x them, but I have no clue. They're is a bi-amp neutrik input. I just have normal 2 channel amps and a DBX crosover. Do I need a special Peavey "bi-amp" amp to properly x these speaks?
Old 03-14-2007
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
You can make a cable assembly as follows:
Materials:
1 Neutrik NL4 connector
2 Neutrik NL2 connectors, or what ever your amp has on it's outputs
2 lengths of speaker cable to go from amps to speaker
Connect both pieces of cable to the NL4, 1 to 1+/-, the other to 2+/-. This plugs into the biamp jack on the Peavey. The one connected to 2+/- goes to your high amp, 1+/- goes to your low amp.
You need one of these for each box. If you run more than one box per amp channel, use banana plugs at the amp end, and stack them.
note- pay attention to how your amp outputs are wired if it uses Speakon outs. For instance, if your amp uses 1+/- for it's outputs, the cable that drives your highs will be 1+/- at the amp end, and 2+/- at the speaker end. Make sure you label which one goes where. I just mark them HI and LOW.
Alternate method:
Materials:
1 rack space panel loaded with 2 NL4 panel-mount connectors
2 short pieces of speaker cable
1 long piece of four conductor speaker cable
2 male NL4
The assembly is the same, but your amp outputs run to the panel and connect to the NL4 there. Then you make an NL4-NL4 speaker cable to go from the panel to the box. Same end result. Less hassle, but more money up front. You could have the panel loaded with XLR or 1/4" for your amp or crossover inputs as well.
You can use this method "on the cheap" if you skip the panel and just let the panel-mount connector dangle. Neutrik makes a back boot for just this purpose to cover up the exposed wires.
Old 03-14-2007
Gnash5150's Avatar
Lefty
Nice. Thanks, man, this is the direction I was heading in, but I had to hear it from someone first.
amp schematics dragonworks Guitars and Basses 1 02-20-2007 11:53
Amp Modelling question..... true-eurt Guitars and Basses 88 10-21-2006 04:33
amp wattage marshall.amps Guitars and Basses 73 09-14-2006 16:16
New webpage explaining speaker impedances, etc. gusfinley Guitars and Basses 11 12-04-2005 04:27
Lexicon 284 Class A Recording Tube Amp Pearldiver Free Ads for Music / Recording Equipment 2 08-02-2002 19:30
