Protools sample rate/adat hardware
Hi,
Question... i noticed that i am having real sync problems with reason and protools when i change my hardware setting in protools over to optical. I have my triton hooked up via adat into my digi002. So the only way to not get a noisy sound when i play the triton is to change it over to optical. I also noticed for the first time... i've had this thing for almost 2 years.. that the triton will only do 48k to 96k sample rates. Well geez whiz... now my tascam cd-rw 2000 is saying error not 44.1k, when i try to master down to it. Ok so i created a new song session and changed my sample rate in protools to 48k then things started syncing up right, but still get some noise if i don't change the hardware setting to optical... clock syncing... I am wondering now if i turn off the digital direct on my tascam burner what sort of sound quality i will be getting. It is suppose to have built in AD/DA conversion.. but this is a new one on me. Anyone else using lightpipe??? that's having sample rate issues? Demi |
It's crazy to answer my own questions, but i figure that this information might help someone else who is having the same problem. I had to grab at the manual to fix this problem. My tascam cd-rw2000 has a feature called digital direct.. it allows you to turn on/off the input sample rate frequency so that digital devices with sample frequencies more than the 44.1k standard will be usable. Ok so i turned it off and wow... i can actually hear that my mixes are a little on the loud side. I was able to lower the input volume and record my mix just as it sounds direct out of protools on to a cd. Sounds 100% better than a bounce to disk.
I love Tascam... Demi |
| is there anyone here who DOESN'T use ANY HARDWARE 'BEAT MACHINE' at all to compose?? | greenleaf2001 | DJ & Hip Hop Production | 36 | 04-23-2007 17:19 |
| newbiw - protools hardware advice | aidan_m | Newbies | 5 | 02-12-2007 06:35 |
| When I export as WAV - how is the downsample done? | sjfoote | Mixing / Mastering | 50 | 12-27-2006 09:09 |
| MOTU 828mkII Interface compatiable with Mbox 2 and ProTools? | pisces7378 | Digital Recording & Computers | 1 | 10-10-2006 17:46 |
| Softhware VS Hardware! Read here | toka | Digital Recording & Computers | 2 | 04-15-2001 15:10 |
