Old 03-06-2007
Colwarter Colwarter is offline
Junior Member
Colwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud ofColwarter has much to be proud of
Digi 002 with Cubase on a PC ? Does it work?
Right now I have a Presonus Firepod. I want to upgrade to the Digi 002r. Will it work on my PC and with Cubase SX or Nuendo? Thank you very much. Alex
Old 03-06-2007
Renascent Renascent is offline
Senior Member
Renascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond reputeRenascent has a reputation beyond repute
If you're not using protools, you'd probably be better off looking into other interfaces. Most people run 002's because they want 8+ in's to PT LE
However, whatever the case, it should work. My mbox works with Logic just fine! Cheers,
Scott
Old 03-06-2007
cello_pudding cello_pudding is offline
Force of Nature
cello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond reputecello_pudding has a reputation beyond repute
doesn't sound like a good upgrade to me...
doesn't the firepod have 8 preamps...and they're decent.
002 has 4 preamps...4 ins...and preamps are...ok.
what are you shooting for here?
Old 03-06-2007
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Maybe try buying your software first.
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 03-06-2007
Junior Member
Actually, I use only one input (one channel). I don't need 8 or 4 inputs. I will also buy a Universal Audio channel strip (LA-610), so I don't care if the preamps on the interface are good or not. I just want a nice interface with good monitoring and easy to use. Do you have any suggestions? I'd like to have a rackmount unit, if possible. Thank you very much. Alex
Old 03-06-2007
ozraves ozraves is offline
1K Silver Member
ozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond repute
There are lots of options...
Echo Audiofire probably has the best rep at this time for lower end (or mid level depending on your perspective).
Any of these will sound better than the Digi 002.
Steven
Mojo Pie
Gear reviews, forums and blogs
Old 03-09-2007
Senior Member
If you're bypassing the pre-amps and you're not using Protools, I'd keep the firepod. Maybe pick up a little Mackie 1202 mixer for a little more control over monitor mix, but the firepod should have sufficient outs. I might be wrong!
Depending how many monitor outputs you need, you might be able to get away with a firebox, or any of the other afformentioned interfaces. 1 or 2 inputs is fairly easy to get for relatively cheap!
Any Faults with Digi 002 Rack ? alecmcmahon Digital Recording & Computers 2 07-22-2004 00:00
Presonus Central Station DA or Digi 002 DA??? theodd Other Equipment and Reviews 7 07-04-2004 18:57
adding 8 more inputs to a digi 002. maskedman72 Digital Recording & Computers 9 10-09-2003 03:06
The Digi 002 vs. MOTU 828 shortyc Digital Recording & Computers 0 10-31-2002 14:40
Digi 002 vs Roland si24 vs 828 & mackie control? rups712000 Other Equipment and Reviews 2 10-11-2002 01:47
