6L6 or 6V6 any difference?
Hi!
6L6 or 6V6 any difference? can I put 6V6 tubes on a marshall jcm900? Thanx! |
Wouldn't recommend it. They have different characteristics, and a circuit mod would probably be required to keep your rig from melting down. However, you can give it a shot and let us know how it turns out.
http://www.myspace.com/sundrone |
Thanx!
and how about preamp tubes? can i use 12at7, 12au7 inted of 12ax7? |
Just stick with 12AX7 and the stock 5881 tubes. If you don't like the sound of the amp, sell it.
I do like the sound, I was just wondering why there are so many types of tubes.
are 5881 same as 6l6?
All of these answers are readily available on Google!
you'll need to rebias the amp if you try 6V6's... they may not last too long otherwise... 5881's are industrial/mil spec 6L6's... no reason you cant sub any of the 12a?7's... ax's are highest gain... so dont expect to overdrive anything with au's aw's etc... and going the other direction if it calls for say at's you can in most cases try ax's the exception is the phase inverter tube... (usually the last before the outputs)
6L6 ~40 watts per pair Different biasing, etc; not interchangeable without other work on the amp. |
#12
Thanx to all for the info.
#13
If I might hijack this thread for a second, what are the differences among 6l6 tubes - like between 6L6GC and 6l6WXT, for instance?
#14
gc stands for Glass Case i think, I know the G stands for glass, the other I couldn't tell ya.
| ANybody here think High End Pre's are Overrated? | MadMax | The Rack | 174 | 09-13-2006 17:34 |
| Omni Studio/Audio Buddy any difference? | ella | Microphones | 0 | 03-11-2003 12:02 |
| Difference between track and channel? | braveheart | Newbies | 8 | 12-07-2002 05:38 |
| Hardware v. Software Effects - What's the Difference? | bongolation | The Rack | 15 | 06-21-2001 00:57 |
