Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 02-26-2007
RAMI's Avatar
RAMI RAMI is online now
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Mono mixing...
When I do a song, the last thing I do is put things in the stereo spread. I do all my volumes, eq-ing, effects, etc...in mono, with everything panned up the middle.
It just hit me that this might not be what people mean when they "checking the mix in mono". Should I be placing everything in stereo and then hitting the mono switch??? There is a difference. The relative volumes wouldn't be the same because the tracks that are already panned up the middle would be more "true" to their volume than the panned ones when switched to mono, no? So, have I been doing it wrong all along?? Or is it just another way and not really that much of a difference.
Does this question make sense?
Old 02-26-2007
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
I think what most people mean is to mix in stereo and check in mono. Or at least spend some time in mono, but have the stereo mix be the base mix you work from.
http://www.misterpotts.com
Old 02-26-2007
RAMI's Avatar
www.ramirami.com
Right. I was beginning to think so. Mainly because I found that once I started putting things in stereo, I had to pretty much re-adjust all the volumes. I guess it can also be looked at as just doing one before the other, you'll have to do both anyway. But I'm going to try the same song both ways and see what happens. Thanx.
Old 02-26-2007
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I tend to get the mix as close as I can in mono, then pan - and yes, you'll very likely want to adjust levels - then adjust in mono again.
If you can get all the instruments to "be nice" in mono (not fighting for space, etc.), then you're almost insuring good focus and separation in stereo.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 02-26-2007
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
I think what you're doing is a good technique. Once you get everything panned, you may need to make a few tweaks, but you'll have a solid mix that will translate well to mono if you do most of your mixing there.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 02-26-2007
Llarion's Avatar
Llarion Llarion is offline
Autosycophant
Llarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond reputeLlarion has a reputation beyond repute
Yes, there is indeed a difference. You don't use a very big soundfield on most of your stuff, and this may be part of the reason. Personally, I mix for stereo, and I check it mono, and I check it on seven different audio sources (Studio monitors, PC speakers, boom box, car, "real" stereo, good aftermarket iPod buds, studio phones). If it doesn't pass the car test and iPod buds test, it's back to the drawing board. For me, oddly enough; my car stereo reveals more of my bad imaging choices and bass EQ issues than any other medium. The studio monitors are seductively deceptive.
Cheers,
Phil Traynor
My website
Watch for my upcoming CD, Autumn Breeze, coming fall 2009
"Gwooum, gwopum, muck-muck." - Unknown
Old 02-27-2007
RAMI's Avatar
www.ramirami.com
Thanx guys....I can see valid reasons to do both, but as Llarion and others have said, mixing in stereo and checking in mono is something I'm going to try. I just had this thing about "I don't want to hear it in stereo at all until I get it sounding as good as possible in mono, then it's GOT TO sound good in stereo".
Old 02-27-2007
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Mono checks are for
- those who's ears are not yet trustworthy enough to be able to tell how two sounds compare side-by-side and can only tell by comparing them stacked on top of each other. And if I have track 5 at 30% R with track 7 at 65% L, then it really doesn't matter if one winds up covering the other in a mono check, unless your one of...
- those who cares how their stuff sounds on AM radio. In which case you got more issues to worry about with your mix than just mono compatability.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 02-27-2007
RAMI's Avatar
www.ramirami.com
Originally Posted by SouthSIDE Glen
Mono checks are for
G.
So, other than for phase issues, you say it's an un-neccassarry step I'm adding????
Whether it's useful or not, I found it was good practice for someone with less-than-pro engineering abilities like myself. I found it really forced me to work with the mix instead of just relying on panning something somewhere to give it it's own space. Maybe I'm over evaluating the importance of it all.
Old 02-27-2007
Llarion's Avatar
Autosycophant
Maybe; ultimately, if it sounds right, it probably is... ("right" being highly subjective, of course, but I've never heard a significant issue with any mix I've heard of yours...)
Cheers,
Phil Traynor
My website
Old 02-27-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
Of course, I've seen plenty of small desk stereos/radios that only have one speaker, so one would assume that whatever signal is coming into that thing is getting pressed together into mono to come out the speaker. While it might be wishful thinking to say that you have to worry about how your mix sounds coming in through the radio, these players also have CD, etc., so I do think it is still necessary to test your mix in mono... if someone pops that CD into a little desktop player that plays back in mono, you don't want half your frequency range disappearing
And yes, technically, things should be recorded properly so that that sort of thing wouldn't happen - but for a lot of us novices, how would we know unless we made a mono mix? Just seems like a step that doesn't take all that long and does provide some sort of useful information, even if it is just for peace of mind.
Originally Posted by Ford Van
I AM RIGHT
  #12
Old 02-27-2007
I love it when folks inadvertantly answer their own questions . No, Rami, I'm not saying it's an unnecessary step, any more than I'm saying that training wheels or a skyjump tether are unnecessary. What I'm saying is that unless one is actually creating a mono mix, mono checking is IME in the same category as those other two tools; it's a wise thing to do until you don't need to anymore.
But, if you're good, the time will come when the mono checking is no longer necessary to ensure a good mix; your ears will know without having to go through the extra rigor. When will that be? When you reach the point where you do a stereo mix and you find very little, if any, problems in mono, and/or you can predict hat when you go to mono that sounds A and B are going to clash.
And as far as phasing issues go, remember, checking that in mono only matters if you really care about the mono mix. Phasing issues in stereo will be audible in stereo, no need to check for them in mono unless you are really concerned that people are going to be listeing to your stuff in mono. If you're creating a CD or a demo disc or something to put on meSpace or something, the chances of that stuff winding up on a mono broadcast or on a player with only one speaker somewhere are electron-microscopically small. And if your stuff does wind up there, it's probably because you've already broken through to the other side; which means that your mixes must have been just fine if people liked them that much .
G.
Glen J. Stephan,
  #13
Old 02-27-2007
Ford Van's Avatar
Ford Van Ford Van is offline
Banned
Ford Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond repute
Very few listening environment are truly stereo for the listener. Also, in cases of a boom box, if you are not in fact VERY close to it, you wind up hearing everything in mono anyway.
What I am getting at is that I wouldn't give my credence to what Glen is saying here. There are MANY instances when your music will be heard in mono (for all practical purposes) and you still need mono compatibility if you want the mix to translate.
There are other acoustical phenomenons that come into play on how sound interacts in a stereo environment on how tonal aspects are perceived that I cannot describe well enough to make any sense, but at least get the gist, which is that ONLY if you can reproduce the same stereo environment upon listening can you appreciate the mix as intended. Thus again, some mono compatibility is advisable. It has something to do with how sound develops/volume/tonal shape.
I can guarantee that if you spent at least 40% of your mixing time in mono, your mixes will sound noticeably better. I have spent as long as 75% of my time in mono on some stuff, and managed some of my best mixes that way.
  #14
Old 02-27-2007
RAMI's Avatar
www.ramirami.com
Cool. It was an honest question, I wasn't trying to put words in your mouth.
Looks like I'll be going mono for a looooooooooooong time.
OK, here's where 2 guys who's knowledge of all this far surpasses mine. Ford Van disagrees here. (not trying to stir anything up, but it's right there in black and white on the 2 previous posts )
And Ford's examples of "boom boxes" and certain rooms and systems makes sense to me. Actually, I wasn't even checking my mixes in mono for that reason, but now that I think of it, there's something I didn't think of.
I guess, for the sake of practice and getting better, it doesn't hurt to do it both ways. Thanx guys.
  #15
Old 02-27-2007
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
Why would anyone listen to a stereo mix in mono?
I know there will be a few radio stations that still transmit in mono, but there cant really be that many left now.
Eck
Million dollar ears.
CRYSTAL MIXING
MY BAND
  #16
Old 02-27-2007
RAMI's Avatar
www.ramirami.com
For the reasons stated in Ford Van's post...Also, phase issues, etc. It's a lot harder to get everything to sit wellin a mono mix. I don't think many of us here can claim to be good enough at mixing to not NEED anything.
  #17
Old 02-27-2007
ecktronic's Avatar
Good stuff Ford Van.
My mono mixes usually sound pretty similar. When I listen in mono the guitars dissapear and the vocals apear louder since the guitars phase and loose volume.
I wouldnt say they sound very good in mono, but neither do commercial mixes.
Eck
CRYSTAL MIXING
MY BAND
  #18
Old 02-27-2007
Ford Van's Avatar
Banned
Eck
I would venture to say that there is a whole new "breed" of mixing engineers who cannot shake a stick at the more popular guys from 10 or more years ago! Oh well.
  #19
Old 02-27-2007
Bartman's Avatar
Bartman Bartman is offline
I count on me
Bartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond reputeBartman has a reputation beyond repute
Once you go mono....
Once you go mono.....you'll never go back!
Seriously, I always check my mixes in mono for possible phase issues or to identify an opportunity for greater clarity. Seems to work OK for me.
My music is here:
http://www.soundclick.com/bands/pagemusic.cfm?bandID=274310
  #20
Old 02-27-2007
danny.guitar
Guest
Posts: n/a
Eck
If you listen to a lot of classic rock stuff you'll notice the mix sounds just as good in mono as stereo. In fact, in a lot of songs there's not much difference. I don't listen to most modern music, so I can't really comment on that.
  #21
Old 02-27-2007
I don't disagree with Ed's reasoning, really. And I don't really want to come across as a guy who's puuting his foot down and saying that mono checking is stupid or bad or wrong or anything like that. We keep this discussion going for much longer and that's how it'll come across; but that's not really what I'm saying.
I still do mono checking on a semi-regular basis, it really depends upon the mix. If there's something going on the the mix that's a usual suspect for phase problems - like doubled lines, for example - then, yeah, I'll check for potential phase problems. But if I am doing a typical 5-piece rock, pop, or R&B combo with arrangements where there is not a lot of line doubling going on*, it's usually fairly evident to the experienced ear where and when potential phase conflicts may arise, and in those instances I will indeed check. But honestly, assuming the tracking and EQ shaping of those potentially conflicting tracks is done something close to right, by the time the mix gets to mono, the phase problems are usually inconsequential.
Where I do disagree with Ed somewhat - though this I believe is more of a personal judgement call and not a declaration of right and wrong - is the idea of mixing for off-center boom box listening or similar horseshit listening enviroments. It's just not worth the studio time, IMHO, to worry about that. Under those conditions, A) it's going to sound like crap anyway, and B) the listener isn't going to be critical about the mix.
Finally, once again, the subject totally ignores the techniques involved in 4D mixing and design, where mono mixing is simply not part of the playbook, where issues like combative tracks are mostly handled long before a rough mono check comes up in the checklist, and where translation to listening to the mix on a transistor radio in a coffin is not a major consideration .
If mono mixing or it's close cousin, LCR mixing, are your bag, and they work for you, then more power to you. I'll not say you're wrong for using those techniques and methods. What I am saying is that if you don't use the mono mix technique like Ed does - and there are many of us, pro and amateur alike, who use alternative techniques - mono checking becomes less necessary as you become more proficient at the more textured mixing techniques. It's still done when called for, but it needn't be the unalterable commandment chiseled in marble that it can be made out to be in short, pat, oversimplified media such as your average forum post. That's all I'm saying .
It's not that Ed is wrong and I'm right, or vice versa (though I'm sure Ed will come back and say it *is* vice versa ). It's two different ways of approaching the situation. Admittedly, Ed's is easier. I prefer mine nonetheless. Make your own choices. Just don't get the idea that mono checking was, is, and always will be a necessary tool to use on every mix, and that if you don't use it, your mix will automatically suffer for it. That's way to simple and incorrect of an answer, right in line with you gotta use an LA2A on every mix, IMHO.
*I don't know whether its geography or age, but I gotta tell ya that the amount of doubled distorted guitar lines alluded to on this board in one day is about three times the number that will cross my path in real life in my entire lifetime. This board is so hard rock and metal-biased as compared to the typical recording and performing acts in my area as to feel as though I'm on two different planets.
G.
Glen J. Stephan,
  #22
Old 02-27-2007
I agree with this completely--excellent advice in my opinion. Checking mixes in mono and spending time mixing in mono is not something you outgrow or eventually throw away like training wheels. It's an important technique and reality check for mix engineers of all ages and experience levels.
While experience may lower the need to do anything more that check in mono, doing is still something that gives the mixer important information. Even if it is just to confirm that everything is indeed working okay in mono.
  #23
Old 02-27-2007
ecktronic's Avatar
I took a listen to your mixes. They sound a bit thin. Maybe that could be something from trying to create too much space by mixing in mono aswell as stereo, and the pan balance is off to the left a bit in the 2nd mix.
Eck
CRYSTAL MIXING
MY BAND
  #24
Old 02-27-2007
RAMI's Avatar
www.ramirami.com
Let's not start cririquing each other's mixes. That could take a turn for the worse.
  #25
Old 02-27-2007
Bartman's Avatar
I count on me
Eck
You may be right. What song are you referring to?
My music is here:
Mono To Stereo Tips 7string Mixing / Mastering 3 08-19-2005 08:07
Question about HipHop/Rap Mixing SwurVe Mixing / Mastering 54 08-02-2005 11:22
Question about HipHop Mixing SwurVe Mixing / Mastering 0 07-29-2005 22:13
MONO or STEREO in live mixing? music4all Mixing / Mastering 22 06-18-2003 18:09
why are we still mixing in mono? fenix Mixing / Mastering 16 06-18-2003 08:20
