Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 02-23-2007
NTK88's Avatar
NTK88 NTK88 is offline
Fixxxer
NTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond reputeNTK88 has a reputation beyond repute
Need help Drumagog
I have Adobe Audition 2.0 and when I tried putting the DLL file into the plugin directory, Adobe said it was unsupported
Also, will this only work if each drum is tracked or can it work with different sounds on the same track?
Old 02-23-2007
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
You can take a stereo drumtrack, and drumagog each drum. I will explain how, if that is what you have to do.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 02-23-2007
NTK88's Avatar
Fixxxer
Yes but 1st I need to make it work with adobe 2.0
Will it work in sound forge 8.0?
Old 02-23-2007
NTK88's Avatar
Fixxxer
Ok nvr mind I got it to work.
How do I make it work on a stereo track?
Old 02-23-2007
NL5's Avatar
NL5 NL5 is offline
Unpossible!
Well, there are two ways that can think of.
Take and bounce the track to mono.
Then make as many copies as you have drums you want to gog.
Next, remove everything from the track but the snare hits. Label that track as "snare"
Do the same for all the other drums.
Then, use drumagog to replace each drum on each track.
Now, you have two choices. Blend the gog tracks with the stereo track in full, or go thru the stereo track and duck, or delete all the drum hits. Most natural would be to duck the hits a bit with automation.
It will be a lot of work, but it's about all you can do. (unless someone has a better idea)
Old 02-23-2007
NTK88's Avatar
Fixxxer
hmm well with the demo there are crappy samples anyway
Thanks for the help though.
Old 02-23-2007
NL5's Avatar
NL5 NL5 is offline
Unpossible!
What kind of music?
Old 02-23-2007
NTK88's Avatar
Fixxxer
What kind of music?
Hard Rock.
I like the sounds on all of Metallicas 1990's work, and tools 10,000 days.
Old 02-23-2007
NL5's Avatar
NL5 NL5 is offline
Unpossible!
Hard Rock.
Go get Andy Sneap's samples off the drumagog site. They are free. They are great for just about anything, but especially hard/heavy rock.
Old 02-23-2007
NTK88's Avatar
Fixxxer
Thanks for the info.
It seems like more trouble than its worth for me, since I would have to comb through 10 different tracks and delete all but one instrument.
Old 02-24-2007
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
If you have 10 tracks of drums, why do you have to delete anything?
BTW, the demo doesn't let you use your own samples.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
  #12
Old 02-24-2007
NL5's Avatar
NL5 NL5 is offline
Unpossible!
He was using my method above to create drum tracks from a stereo drum track.
It is a lot of work, and it's hard to say if it would be worth it without hearing the actual track.
Sorry, I didn't know the demo didn't allow you to use your own samples.......Drumagog is well worth the price though, and Rim is a great guy.
  #13
Old 02-24-2007
Farview's Avatar
Yup, that's a pain in the ass. Sometimes you can set up a gate with a key insert to do some of the work for you, but it is still time consuming.
Jay Walsh
Drumagog woes.. inmyheartx Mixing / Mastering 23 01-22-2007 20:31
Fs: Drumagog Pro Discounted Drummerbones Free Ads for Music / Recording Equipment 5 04-13-2006 11:07
Drumagog Help ryanformato Drums and Percussion 3 10-20-2005 13:19
Drumagog Freezing Up N-track Drummerbones Digital Recording & Computers 5 07-26-2005 07:38
Drumagog freezing up N-Track Drummerbones Digital Recording & Computers 4 06-20-2005 10:33
