Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 02-20-2007
Chill Chill is offline
Senior Member
Chill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond reputeChill has a reputation beyond repute
Compressor tutorial or FAQ, esp re drums?
What are your favorite compressor tutorials or FAQ's? I found this one with sample settings: http://www.rane.com/note1558.html
I'm trying to get drum sounds to be a bit more even dynamically without turning to mush, in particular the kick drum. A quick search here and on google suggests tweaking the attack time. How do you apply compression to recorded drums?
And, for multiband compressors on a stereo mix, what are your rules of thumb or starting points, and what are you listening for as you tweak the settings?
DIY!
Old 02-20-2007
jonnyc jonnyc is offline
2.5K Gold Member
jonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond repute
If you do a search there's actually a compression tutorial on this site. I think maybe SouthSide Glen was the one who wrote it, either way just do a search it's around.
Old 02-20-2007
flatfinger's Avatar
flatfinger flatfinger is offline
Use every dam bit!
flatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond reputeflatfinger has a reputation beyond repute
the link is in his sig.
Highly recomended. Theres also some good ones at the sos archive.
Originally Posted by NYMorningstar View Post
This thread is full of as much bad info as it is good info. It should be deleted not stickied or whatever it's called. Save us all the trouble of reading it and maybe we can all get back to important stuff like mixing & mastering.
Old 02-20-2007
Ford Van's Avatar
Ford Van Ford Van is offline
Banned
Ford Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond repute
This article has audio examples! It is an excellent read. Doesn't tell you much about what everything on a compressor does, but it shows excellent examples of what certain settings will do!
http://www.recordingproject.com/arti....php?article=6
Old 02-20-2007
flatfinger's Avatar
Use every dam bit!
Here's another
http://emusician.com/mag/emusic_big_squeeze/
In the paragragh "improvment plan" ignore the statement about using all the bits for better resolution: thats 16 bit thinking. Not applicable to 24bit. The article was writen on '01
Old 02-20-2007
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
See below
G.
vvvvvvvvvvvvvv
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 02-22-2007
Senior Member
Thanks, all!
DIY!
Drums from A-Z: My Approach LeeRosario Mixing / Mastering 5 04-10-2006 01:34
all about sequenced/sampled drums n8tron Drums and Percussion 8 01-30-2006 20:47
mixing drums, gain, and compression question fl junkie Mixing / Mastering 2 11-03-2005 19:28
My drums sound boring gasal69 Roland, Boss, VS Series Forum 13 04-22-2005 10:53
