Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 02-19-2007
pennitentiary pennitentiary is offline
Newbie
pennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond reputepennitentiary has a reputation beyond repute
I Need Help Choosing A Pre Amp For My Mic On My DAW... Thank You For Helping!!!
Hello,
I have a really quick audio question to ask. I'm basically buying a microphone for home studio purposes (vocal), on a desktop application workstation using "Adobe Audition" to record & mix. This is the microphone I am getting:
Studio Projects "TB1" Microphone
http://www.studioprojects.com/tb1.html
I plan to buy a pre amp for it and I'm having trouble choosing between these two:
ART TubeMP Project Series (Portable Preamp with 12AX7a Tube and 70dB Gain)
http://www.sweetwater.com/store/detail/TubeMPps/
Or
M Audio DMP-3
http://www.sweetwater.com/store/detail/DMP3/
A friend of mine said this about the Art Tube pre amp:
"An ART TUBE preamp is a decent preamp but if you plan on getting a tube mic then I'd suggest getting a solid state preamp (something like the m-audio DMP3... but the ART TUBE preamp is good still because I think you can turn off the tube sound"
I have no idea what he means by that... All I know is I need one of these two pre amps because they both fall under my budget for a pre which is under $200. It does'nt seem as if my friend is sure that the Art Tube pre will work well with this microphone since he also mentioned the other one. Not to mention he said something about turning off the "Tube Sound". I'm sort of a novice at this so sorry for the bother.
What do you suggest?
Thank You
By the way this is the setup I will be buying:
1. Studio Projects "TB1" Microphone
2. ART TubeMP Project Series (Portable Preamp with 12AX7a Tube and 70dB Gain)
UNDECIDED ABOUT THIS PRE!!!!
3. M-Audio Audiophile 2496 Sound Card (unbalanced)
Or M-Audio Audiophile 192 Sound Card (balanced)
http://www.canadacomputers.com/index...=007605&cid=SC
(2496)
http://www.canadacomputers.com/index...=007600&cid=SC
(192)
4. Microphone Stand
5. Metallic Pop Filter w/ Long Goose Neck
Old 02-19-2007
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
You cannot "turn off" the tube portion of the ART tube pres. I would recommend the DMP3 or then Rane MS1B. If you really want to play around with the "toob" sound (not really worth it, imo), check out the Studio Projects VTB1. You can run the VTB1 entirely solid-state, or blend in a little toob distortion.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 02-19-2007
Newbie
What exactly do you mean by this? I'm sorry I'm quite the novice and I'm buying this equipment so I can record albums at home.
Old 02-19-2007
danny.guitar
Guest
Posts: n/a
Tubes color sound. Sometimes in a good way, other times, like in really cheap gear, not so good. And what kind of "color" you want is usually a matter of taste.
What he's saying is if you don't like the sound of the tube pre, you're stuck with it.
A clean/transparent pre like the DMP3 might suit you better until you can afford a nicer tube one.
Old 02-19-2007
Newbie
Thank you for your response.
A friend of mine said this:
the art tupe pre may be just a bit better of a choice because it is a metal chassis and you can control the tube circut.
What would he mean by this?
Old 02-19-2007
Big Kenny Big Kenny is offline
Been Here, Posted That
Big Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond repute
It means you can attenuate the amount of "toobiness" by the turn of a control knob. The Tube mp you are talking about does not have this "V3" technology. This one does http://www.artproaudio.com/products....&ca.t=1&id=99s Get the DMP3
In His Name
Big Kenny
Old 02-19-2007
tdukex tdukex is offline
Man of the Muse
tdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond repute
The DMP3 excells on acou guit. The ART doesn't.
Old 02-19-2007
Newbie
Maybe I also forgot to mention that this is for vocal recording... Thanks For responding.
Old 02-19-2007
pohaku's Avatar
pohaku pohaku is offline
1K Silver Member
pohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond repute
Given the choice -- DMP3. No contest.
Yeah I'm an attorney, but everyone needs a day job.
Old 02-19-2007
scorpio01169's Avatar
scorpio01169 scorpio01169 is offline
Senior Member
scorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond repute
i have an A R T tube pre....and i love it. i use it with a studio project b1 and the samson co1, for the cost you cant go wrong
Mackie 32.8+24.E plus automation
[2] Mackie MDR 24/96 mtr
e-machines pc/Nuendo for tracking and editing
m-audio firewire 410, samson c01, audix d6, samson tom mics Alesis qs7 keyboard controller, Korg Triton Rack, A R T,preamps
Old 02-19-2007
gracejames gracejames is offline
Newbie
gracejames is on a distinguished road
What kind of music are you recording? So, i assume this new pre will be for both vocal and all other instruments?
  #12
Old 02-19-2007
Newbie
This will be used for rap and r&b music.
It seems as if most of you seem to be geared at the M Audio DMP3 pre amp for use with a Studio Projects TB1 microphone. I guess I'm going to have to go with all of your opinions. I hope it does great on my vocal music recordings.
Does anyone have anymore pros/cons about the DMP3? Or feel as if I should buy something else? Remember my budget on a pre is under $200
  #13
Old 02-19-2007
Newbie
Ok. Yeah, with your budget and doing rap/r&b, i would go for DMP3.
mic pre amp? antispatula The Rack 4 11-08-2005 19:31
mic pre amp, compressor, voice ripper RoOkiE85 The Rack 1 09-12-2005 10:19
noob Pre Amp for Vocal Mic Question tonyoci Microphones 1 07-11-2005 19:25
Mic pre amp question Glenn Cimera Fostex Forum 3 01-20-2005 05:42
Mic Pre amp ashulman Microphones 15 03-10-2003 00:56
