Giving each instrument its own EQ Space
Is it better to boost say 2 or bands in a row rather than splitting bands?
For example if I wanted to dip some mids out of bass and guitar so that they have a mid range presence, would it make more sense to maybe dip 500-630 HZ from the guitars and 315-500HZ from the bass rather than 315 from bass, 400 from guitar, 500 from bass, 630 from guitar? |
Not to side step the question, but does this presume that they both already have had they're basic shapes and hot spots delt with or they're ok in that respect?
With that in mind I just tend to look for the best way to fit things with the least amount of moves and a) move to a parametric so that you're not stuck with predefined centers and widths, and b) the 'extra split bands' seems kind of 'zig zag?
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
I'm with mixsit, if you really want to carve out space for instruments then you need parametric eq. To keep things sounding natural and like your mix hasn't obviously been 'processed' you need to be able to ascertain and deal with the actual frequencies that need work, and you need to be able to define the bandwidth.
Using a graphic eq for this purpose is a bit like using a machete for micro surgery.
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time." C. M. Burns http://www.shuttleworths.co.uk/micloop.gif |
Haha I see, well thats why I am here asking these questions
Ok so ill look into how to use that EQ method rather than a graphic EQ. With that said, are there any programs that I can actualy see the frequencies in the form of say bars on a meter? Abobe has a feature where I can gather a line graph of the frequencies but the chart is so damn small I would need a magnifying glass to read it! Also what are hotspots? |
But I'd stay away from RTAs for now and concentrate on using your ears to learn the frequencies; that'll get you a LOT further to getting a good mix than any pictures will. Do a search of these forums for "parametric sweep" to find several posting describing one of the best methods to using parametric EQ to tame "hotspots" (bad sounding resonant frequencies in an instrument track) and to get instrument tracks to beahve. G. |
It all depends on how the tracks are recorded.
Unfortunately there is no set way to so things like this IMO. Eck |
There's a few ways to go here. Fixing the things on the individual tracks that appear obviously out of whack might be first, but also how they (and everything else) fit together in the mix will ultimately determine how they should be shaped. You can see these as possible two separate thought processes that go on as you dial in. This is all just part of the basic shaping. Fine tuning with more micro stuff works as needed (and when you can hear them better) after the bigger moves. ![]()
| How do lights and wiring affect potential studio space? | leavings | Studio Building & Display | 3 | 01-11-2005 18:05 |
| Your opinions please on building a home studio/practice space in attic (drawing) | Mongoo | Studio Building & Display | 1 | 11-15-2004 21:49 |
| Small studio space: one room or control/live rooms? Help! | gtrplaya | Studio Building & Display | 6 | 09-09-2004 09:51 |
| Freqs Fighting for the Same Space | malcolm123 | Mixing / Mastering | 28 | 02-22-2003 06:58 |
| fill this space | dr.colossus | The Rack | 10 | 04-15-2002 11:20 |
