For most people, the final medium for their songs is 44.1/16-bit on a CD. But for people like me, who mostly just distribute their songs on the internet, the final format is MP3. In this case, 128 KBPS.
My question is, is there anything you can do during tracking/mixing/mastering to ensure you get a good sounding MP3? Should I first make a it sound great for CD? And then make a separate master just for MP3s? What would I do differently? I'm perfectly happy with the way things sound on CD but when converting to MP3 they sound like shit. Keep in mind I mainly do acoustic guitar so that might make it more obvious. One thing I learned is to use very little, if any, reverb as that sounds like ass at 128 KBPS. So for my CD version I'll keep a little reverb, but for the MP3 version I'll usually remove it completely. Also, what frequencies are usually most effected when converting to 128 KBPS? Should I maybe try lowering those nasty frequencies a bit and boost the ones that are less effected to give a better sound? If you run a professional recording/mastering studio and your client also wants a good sounding MP3 what steps would you take? Just convert to MP3 and be done? |
IDK for sure but I find my cymbals sound like shit when I save 128bit mp3.
Probably high end freqs, just the ones to make acoustic guitar shine!!! |
I can't convert to anything less than 192 because it just sounds like shit to me.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
![]() Quote:
I don't have alot to add but i'll say this. The obvious, the better the wav file sounds, the better the mp3 sounds.
Second, most people i know who constantly listen to mp3's and don't make music really will claim they don't hear much difference between a wave file and a 128kps mp3. And i'm inclinded to believe it's alot easier to tell when things sound worse than better. So if your audience is used to that, the quality loss can be concider negligable i guess. Now, the main thing i have noticed with online media players is they do sound different. Myspace for example sounds really flat and dull compared to say windows media player. So trying to mix to that format might be counter productive, if there is a good way to do it to begin with. |
If your reverb was a stereo effect, it sure takes bitrate as well. Mono effects should be less hungry, providing you're encoding joint stereo, which you really should do at low bitrates. If you used a mono mic, 128 kbps actually should do quite well (unless stereo effects are applied). |
I'm going to try it myself - my stuff is all acoustic guitar. Thanks, |
I dunno, but I think MP3 conversion gets blamed for more damage than it really does. Sure, I can hear the difference between 128 MP3 and a CD, but it doesn't totally trash the sound as some people would say. (and I listen in a pretty accurate environment)
Here is a song I am just about done with that I used LAME to convert from a 16/44 mixdown. Pretty clear I'd say. Not as good as the CD version, but definetly not trashed. And, there is stereo 'verb all over it, as well as a bunch of actual room sound. http://www.lightningmp3.com/live/file.php?fid=6590 .
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
#12
I can see why with these combination of things how encoding to mp3 really messes things up. Here is a short 20 second sample of a mastered .wav file of something I mixes, along with a Fraunhofer encoded 192kbs and 128kbs mp3's of the same sample. This is acoustic guitar and vocal. http://www.phoenixlightandsound.com/...test/GEWav.wav http://www.phoenixlightandsound.com/...test/GE192.mp3 http://www.phoenixlightandsound.com/...test/GE128.mp3 Yeah, there is a slight difference between the .wav and 128kbs file, but not much! You should check your encoder to make sure you are not encoding as something like a "fast" encode. I use Audio Active Production Studio Pro app, and it gives me the option of a "Faster encode" or a "High Quality Encode" which is much slower, but produces a much better sounding mp3 too! Here is a 128kbs on "Faster encode": http://www.phoenixlightandsound.com/.../GEfast128.mp3 Still, not a night and day difference, but certainly you can start to hear artifacts. I do not like the Lame codec at all! I will not use it. While it is a subtle difference between it and the Fraunhofer codec, it is a difference I don't like. But, I don't think the codec itself is the culprit with the big difference you are hearing. I think the encoding is showing the weaknesses of your mix.I am always concerned when somebody makes a statement that they are "happy" with their current production results. I have never recorded/mixed/mastered something where I was "satisfied". I just get to a point where it has to be done is all! But I can always find things I would like to improve, thus, I improve every time I work on something. |
#13
edit - and WTF is so bad about LAME - I thought it used the Fraunhaufer codec???
#14
I can hear the results of your new console for sure on that mix! I should get my butt over there to check it all out. There is a certain something that a decent analog console does to the mix that digital just can't!
I am sure that band was VERY pleased with that mix! |
#15
pssssst - don't tell anyone, but that is 100% ITB mix - the console appears NOWHERE on that song. It is up and running, but not quite ready for primetime, and the band kept making changes, so I just kept it ITB to make total recall possible. The Trident was used to monitor during overdubbing, that's it. It really is a shame, cause it sounds badass! Yep, you need to come check out the new digs - it's a whole new ballgame! ![]()
#16
Interesting. |
#17
NL5 - Thanks for posting that clip, sounds good to me. But what I was saying is that for something that is just acoustic guitar, (no vocals, electric guitar, bass, etc.) that maybe the artifacts are more noticeable.
Ford Van - That is an old recording before I got my guitar repaired, it had a lot of string buzz. Some of it was also poor technique because that song is hard as hell to play. ![]() I think I found the problem. I was using the MP3 Pro feature in Adobe Audition because it says it uses the Fraunhofer codec so I thought it would be better. I then went back to cDex and used LAME and it sounds fine. I honestly don't hear that much of a difference between the WAV and the MP3. It's there, but not like before. Please tell me if you hear any noticeable artifacts: www.getmyim.com/temp/guitar_send128.mp3 (~ 800 KB) |
#18
Another problem is, that not all download shops actually use LAME but rather obsolete encoders, often because they bought them years ago with watermarking algorithms included. Quote:
Just a thing I noticed (in the editor), your recording is mono, but the noise floor is stereo, hence wasting a tiny bit space in the mp3. You can try encoding a mono wave, which might improve the result slightly. |
#19
#20
What I've noticed with my own conversions from wav to mp3 is that ANY imbalance in the sound gets magnified during the conversion. If it was a little too bassy it gets WAY too bassy.
If the highs were just a little harsh they get unbearable. If there was a fingering buzz, it's like a magnifying glass is held over every spot where that happened. With 320 kbps mp3s it's less so. With 128 it's much more a problem. The Lame encoder is the best I've found. It makes a difference. |
#21
Although even at 320 KBPs, or WAV for that matter, my mistakes are still pretty obvious. ![]() |
#22
The difference is probably in HOW each program does the encoding. AA is possibly doing a "quick" encode, which cDex is doing a slower, more accurate encode. |
#23
Also every mp3 player I'm aware of will play mono files on both channels. But if you really must convert a 24 bit mono file to 16 bit stereo for some reason, go first to 16 bit mono and after that convert it to stereo. That way, you'll get mono dither. Quote:
#24
LogicDeluxe - Thanks for the tip, I never thought about the mono vs stereo dither or converting to MP3 straight from the 24-bit file.
![]() Ford Van - I don't see any option for "fast conversion" or whatever in AA. In cDex there is "On the fly MP3-encoding". Is that what that is? It is checked by default. Thanks for all the help. ![]() |
#25
| questions, questions, questions | chronicinsomnia | Newbies | 8 | 12-08-2004 18:48 |
| I need a .wav to MP3 converter. Please help. | Sennheiser | Digital Recording & Computers | 7 | 09-06-2002 17:29 |
| How to convert WAV to MP3 at CD Quality..... | NickHall | MP3 Mixing Clinic | 41 | 06-28-2002 12:45 |
| MP3 icons | windowman | Cool Edit Pro / Adobe Audition Forum | 4 | 10-14-2001 22:50 |
| Please try the search before asking questions | ola | Other Equipment and Reviews | 5 | 10-24-2000 02:09 |
