3 questions
1. how do i assign an fx channel to a track so i can use the volume slide thing to adjust the fx e.g reverb. my tutot at college says that its better to use fx channels rather than inserts, i asked why and he said you can control the amount easier, but you can do that with an insert.????
2.when running a jack from my amp to alesis multimix i get huge amounts of gain even when gain is set to 0, this is only when i use an epiphone les paul, to componsate for this gain can i just turn down the track fader level or will this result in less sound quality?? and why do les pauls run so "hot" 3. once all level are set following manuals, guidelines ect i record into cubase. one thing i notice though is that the track wave linesarnt as thick or high as i have usually seen when people use cubase, maybe im just being picky here but i just want to make sure. hope you guys can help. -dave |
Forget about what the track wave displays look like... they can be sized if you want them bigger or smaller. Shoot for -10 or a little higher on the digital meter when you record and you'll be fine. [Tracking level rant moved to another thread] Last edited by The Audio Cave; 02-15-2007 at 18:41.. |
1. Create an efx track or group track and insert efx on this track. Assign one of the send from your audio track to the efx track and adjust the send level.
2. Are you using the amp's direct out? You might need a pad. If it sounds ok and you aren't clipping anything (listen for it), I would just turn down the track after it's recorded. |
| questions, questions, questions | chronicinsomnia | Newbies | 8 | 12-08-2004 18:48 |
| Specific Questions Regarding My Signal Chain | MusicMan91 | Newbies | 2 | 12-26-2003 21:45 |
| Questions about NWR. | TheRealWaldo | MP3 Mixing Clinic | 8 | 11-15-2003 18:00 |
| Please try the search before asking questions | ola | Other Equipment and Reviews | 5 | 10-24-2000 02:09 |
