why am i still getting phase cancellation?
i have a set of vocals and i wanted to try that fattening technique where u send the dry signal 100% into one speaker and u send the 30ms delayed signal 100% into the other speaker so why am i still gettin phase cancellation. i read in alot of books that such as "the art of mixing" that this if vocals are delayed to 30ms it won't cause phase cancellation. any idea why it's doing this? P.S. ive tried this technique on over 20 different vocals just to make sure that it wasnt that paticular set of vocals cause the phase cancellation. thanks for any feedback guys!
Yea, I tried this, too. About 7 months ago, when someone wrote about it here. 10ms, 15ms, 20, 30... tried adding some pitch adjust... tried standing on one foot... none of it worked. I got much better results just experimenting with reverbs that add "room effects". A lot easier, too.
30ms shouldn't give you a phase problem...it should be giving you a delay sound instead. It'll be a strange, wide stereo thing.
What happens when you sum to mono? Are things canceling? Or do they just sound kind of echo-y?
www.redlabaudio.com |
thanks for the feedback. yea things are cancelling when i convert it to mono
give us step by step what you're doing when you route the signal two different places
That's a classic comb filter effect, produced by combining a signal and a delayed version together. At least the nulls are relatively close together, compared to a 1ms delay, for instance, which would produce broader nulls at 500 Hz, 1500, 2500, etc. The fact that you have the signal in separate channels won't entirely prevent this: to a significant degree, the two speakers will basically add at the mix position, sometimes in and sometimes out of phase. Cheers, Otto |
I assume you are using hardware, but software plug-ins may have the same wet/dry mix.
"Tascam, Fostex or Studers don't make hit records...........people do" MCI2424 - 2007 |
| phase cancellation, proper mic setup | random effect | Recording Techniques | 14 | 10-21-2006 13:25 |
| Fun with Phase Cancellation | RawDepth | Mixing / Mastering | 18 | 09-21-2006 22:00 |
| Phase cancellation | brainwashed | Mixing / Mastering | 14 | 09-07-2006 06:14 |
| Phase Cancellation | shreddist | Microphones | 8 | 06-22-2005 10:37 |
| How do I do this (phase cancellation stuff)? | powderfinger | Recording Techniques | 3 | 08-08-2003 17:37 |
