Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 02-14-2007
VGreen VGreen is offline
Newbie
VGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond repute
Going Back to Analogue/Digital/Midi Basics
Below is an attempt to explain some basics in analogue/digital/midi. Hope this isn't too long. I'd appreciate any contributions, and hopefully we might be able to build a useful thread for those like myself who are very green.
All sounds begin as pressure waves, and are then converted by either analogue (electro-mechanical, such as vinyl record, cassette tape) or by digital (electro-digital, such as compact disc) signals by the process of recording. Sounds are always audio, either analogue audio or digital audio, but never midi. Midi isn't sound, but the information about a sound, such as sheet music. It allows us to write or rewrite sounds but isn't sound itself. It is an interface, a Musical Instrument Digital Interface - MIDI.
When a virtual sound is recorded onto say a Yamaha unit, this is done by mic-ing say a violin, recording the analogue signal, converting it to digital, then storing it on a soundcard inside the Yamaha. Then when a note is played on the yamaha, the soundcard converts the signal from digital back to analogue (because we hear in analogue) and we hear the sound.
If I now record a sound in "audio mode" to my ProTools sequencer (recording software) via my MBox (recording hardware) and then play it back through my Yamaha via my MBox, the digital sound travels down the cable to my computer, out of my computer into my MBox where it is preamped (amplified), back to my computer and into ProTools where it is stored as a wav. file (signal) on the sequencer. Then when I play it back, the process is reversed, the digital signal finally reaches the Yamaha and is converted back to analogue through the soundcard and I hear it. Or, if I want to play it back through a speaker (monitor), the digital signal travels from the sequencer to the MBox, is converted back to its analogue form via the soundcard in the MBox, and is then sent through the speaker.
If I now repeat the process but this time in "midi mode", a midi signal containing information about the note I have just pressed (which note, how hard I hit it, how long I held it, etc.) travels to the sequencer. This information is stored as a midi file, and the note can now be adjusted where necessary (moved, made louder/softer, etc.). Then when I play it back, the adjusted information for this note is sent back to the Yamaha, and this adjusted information is now processed through the soundcard, converted to analogue and heard. In other words, midi technology enabled me to do electronically what I failed to do mechanically with my finger. No sound signal travelled between the Yamaha and the sequencer, only the midi signal. The sound component kicked in via the soundcard in the Yamaha only after it had received the midi information - from the sequencer - about the note played. The midi process served only as an interface between the Yamaha and the sequencer.
Please feel free to correct or add to anything I have said.
V
Old 02-14-2007
JoeNovice's Avatar
JoeNovice JoeNovice is offline
Junior Cheeseburger
JoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud of
VGreen - You have a good foundation and basic understanding of what you have put forth. There are a few things you will learn the longer you stay involved with this stuff.
For example, analogue (analog) implies that the signal is already converted to "electro-mechanical." Before sound becomes analog audio it is just sound, or changes in air pressure that we think is sound.
Whenever changes in air-pressure are captured they are converted to identical changes in electricity. The waveform, frequencies, and amplitudes of the changes in electricity directly correspond, or are analogous to, the original acoustic information. Hence the term analogue.
I see you use ProTools. You should buy the book ProTools 101: Offical Courseware by Thomson. I have read it for a class and found it really informative and well written. Part of the analog definition I used came from this book.
7 times down, 8 times up......
Old 02-14-2007
Newbie
Joe,
Thanks for your input (which has now been edited in). Although still relatively green, I've learned most of what I know through Google, message boards and talking to staff who sell the hardware/software. The book you mention looks good; I'll have to try and track one down.
V
Back to Basics jro05 Newbies 18 06-26-2005 16:46
Opinions on mic placement desired Bigus Dickus MP3 Mixing Clinic 11 01-11-2003 19:02
