MIDI from the ARK
Anybody got a Commodore 64 midi cartridge?
Oh yes, I'm quite serious! The Commodore 64 was a nifty little computer which takes quite a high seat in my studio setup. The sound chip, the SID, was a proper semi-pro' analogue synth' shrunk to a chip, so I can tell you that it's very handy. The C64's SID has actually been recognised as a musical intrument in its own right. I've looked on Ebay, but it's absolutely ages until one crops up. (As an aside, I would recommend a C64 as part of your gear, even if it's merely in the form of a PC-based emulator, like one of the Win Vice range. Particularly if you can find a copy of Instant Music, a simple sequencer which allows you to compose bits of music and uses artificial intelligence to keep it all in key, etc. (Someone's selling a job lot of those on Ebay.)) |
You can build a midibox SID for about $50 and just use the SID chip from an old c64
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
Well, mebbe....
Well, it's certainly a way to have the MIDI connectability.
But you lose more than you gain there because a SID box isn't as programmable as a MIDI unit. However, a new line of enquiry could be made as to whether the writers of the VICE emulators could write a MIDI plug-in for their software. That'd solve everything. |
myspace |
Maybe, but if you want jingles in 30 seconds, it's a god send.
http://ucapps.de/midibox_sid.html
What I want a C64 MIDI cart for specifically is not just to run Instant Music from it, but also the other Commodore music packages I have. After running them on the SID, it'll be nice to use the same arrangements playing through other units.
Plus, I can program the SID to make specific sound effects via either compiled BASIC routines or direct machine code programming. I'd have to learn a new lot of things to program the SID in its new environment. |
| Software samples for MIDI, what do I need to know? | Vigilante | Recording Techniques | 3 | 12-06-2005 23:54 |
| How do I hook everything together? | mikara | Newbies | 20 | 09-02-2005 05:27 |
| Midi and Creamware | dangerman | MIDI Mania | 3 | 05-18-2005 00:53 |
| drum machine, Cakewalk, USB MIDI interface, argh | 55337 | Newbies | 14 | 03-09-2005 16:41 |
| Oriion, Rebirth & Fruityloops with Sonar | acgt | Cakewalk / Sonar Forum | 10 | 09-13-2002 13:21 |
