Old 02-07-2001
ducktape ducktape is offline
Newbie
ducktape is on a distinguished road
Hello everyone,
I'm in the planning stages of building my son a small practice studio in our basement. An 8'x8 or 8'x10 (not set on size yet) shell that will be touching the floor and nothing else. I was told that the insulation that is blown in is better to use than the rolled pink stuff- is this true? I realize that with the blown in stuff there would be some settling but I was planning on putting some sort of access panels on the top of the stud walls. I then would remove then and fill in where any settling occured. Please let me know before my wife & I go deaf and there will be no more need for the studio.
thanx,
Ducktape
Old 02-07-2001
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
I think that the batt form is better as it won't settle and frankly to put opennings at the top of your studs would be extremely laborious and a waste of time let alone the problem of having no noggins (what's the US term for that Brian)
Ducktape - I suggest you visit mny site
http://www.lis.net.au/~johnsay/Acoustics
if you are about to venture into acoustics and to the Studios Under Construction site if you are about to build.
http://greysfiles.com/Studio/Index.htm
cheers
john
Old 02-10-2001
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
Originally posted by John Sayers
.....let alone the problem of having no noggins (what's the US term for that Brian)
cheers
john
Hey John,
are you talking about what we call a "fireblock"? (you put a small piece of 2"x4" as a spacer inside the wall-it supposedly helps control/slow down fire since it has to burn through the piece of wood to get into the next channel....probably BS, but who knows?
Tim
Old 02-10-2001
Solar Power!!
Yeah Tim - it is a 2 x 4 spacer but it stops tall studs from bowing and bending.
cheers
John
