Old 02-07-2007
Nate74's Avatar
Nate74 Nate74 is offline
HR4FREBR
Nate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond repute
Should I put spacers behind my bass traps?
I have three wall mounted 2'x2'x2" absorbers along with several corner mounted 4" thick bass traps. In watchin Ethan's video I see that he uses some cylindrical spacers to put about 2" or so between the walls and the traps. Is it worth it on 2" thick absorbers?
I know, I know... try it and see. But I'm at work, daydreaming and not in my studio but wanting to talk about it
Dogman has the best Avatars ever.
Old 02-08-2007
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
A 2" absorber spaced 2" from a reflective surface will act more like a 4" absorber. So yeah, the cheapest way to increase effectivness of absorbent material is by spacing it from the reflective surface, eg wall.
Old 02-08-2007
Nate74's Avatar
HR4FREBR
Thanks pandamonk!
There's a carpet store that I pass on my way home from work. Would a empty tube from a roll of carpet work if I cut it to 2" in length? I seem to remember those things are made of pretty heavy-duty cardboard. Would that be total overkill and is there something better suited?
Old 02-08-2007
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Anything that gives you an airspace will work. Wood, cardboard, PVC, pointy sticks...
Bass Traps cincy_kid Studio Building & Display 25 03-23-2006 13:43
ethan's bass traps vs putting fiberglass in bag Kasey Studio Building & Display 10 03-11-2006 09:50
Bass Compression Question jeffoest Mixing / Mastering 1 11-25-2004 08:35
bass traps detuned6 Studio Building & Display 4 12-06-2001 22:54
