Confused about what cables I need
I have an SM Pro Audio PR8E 8 channel mic preamp (balanced 1/4" TRS outs) which I need to plug into an M-Audio Delta 1010LT with RCA female ins.
Do I have to use a "balanced" TRS 1/4" to RCA cable? Should I use a balanced cable? |
I hear that mic pre is pretty crappy though. If you get some good sounds out of it, please post for us to hear.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
Thanks for the info.
I've heard mixed opinions on the PR8E it. If it matters, it's not the $99 older version (PR8) the PR8E is $199 MSRP. I do not have, nor do I want a mixing console, I work 100% in the box. Only preamp I have now is an M-Audio AudioBuddy which I have been very happy with. I figured the PR8E would give me enough inputs to record a rock band without breaking the bank. And at the worst it could be used solely for drums if it turns out to be a below-average preamp. One of the things I've heard is it has a dip in the 90 Khz area, so may need to bring up the low end with EQ on things like bass guitar and kick drum. but I've heard good things about it, too! So we'll see. |
A dip in the 90 Hz range (not kHz, that's even higher than a dog can hear) is probably not such a bad thing. Anyway, good luck.
I meant 90 kHz
or 90 Hz. Whatever, the LOW one
M-Audio subterfuge
Yes, that old M-Audio confusion here, I fancy.
You see, the thing is that the M-Audio devices like the 1010 have TRS connections alright, but they're UNBALANCED! Yes, unbalanced, balanced 'compatible' connectors! The ring circuit has a dummy load in its works, or some such subterfuge. So, mate, any damn cable works! Don't panic! |
M-Audio stuff is TRS out but not balanced?
So my DMP-3 has TRS outs but is not balanced. Hmm. "We are not amused!!!" |
In a letter to his daughter, the MCP expressed unhappiness over the eagle as the symbol of America, he wanted the Tron guy. Equipment G.F.C.G. # 000 035 |
Thanks for pointing this out. From now on, I'll unbalance my preamps at the bay with TS cords, rather than trust to their unspecified method of unbalancing. Cheers, Otto |
You know, I would like to be sitting here all smug, as if I found that out for myself.
But I'm a fraud. A mate of mine who used to be a 'proper' engineer and producer (ie - who knows how to build and maintain studios and equipment as well as use 'em) told me that. Still, nice to bask in the reflected glory! |
#12
what the hell is a TRS unbalanced??
![]() does that exists? isnt that the purpose of the R in tRs? m-audio=Digidesigns fucked up step sister.
GFCG Member: 000 029 F**k Your Scene. |
#13
I had always had a concern about its maximum rated input of +14 dBu. Now I know that it only accepts one leg, I see it's less of a problem, since that corresponds to a +20 dBu balanced signal. It explains why, when the +16 dBu light lights up on my MixPre, it's not quite overloading the M-Audio input, since it's only seeing about +10 dBu (MixPre outputs are electronically balanced). I'm assuming the outputs are similar, since upon careful reading in the manual, I note that it says the outputs are "compatible" with 1/4" TRS balanced connections, not that it actually has electronically balanced outputs, as I had presumed. Matter of fact, I had noted some puzzling level behavior when connecting up the supposedly balanced "recorder" output to a pair of VU meters. Perhaps the lack of a true, balanced output explains that behavior. I'll have to check it out. Cheers, Otto |
#14
#15
And I'm going to check with M-Audio, because when you see a listing for a connector that is balanced/unbalanced, the idea is usually that it is balanced but can accept unbalanced signals, like you see on many modern mixers. Some of the 1010 connections are unbalanced, some are not. I'd like to nail this down, because this is how really bad info gets spread around. Last edited by boingoman; 02-11-2007 at 11:10.. |
#16
#17
Cheers, Otto |
| I think I'll liven this place up an work on my post count. | monty | Roland, Boss, VS Series Forum | 49 | 11-12-2003 15:56 |
