Tascam 414 Portastudio
I just purchased a Tascam 414 portastudio 4 track recorder. After expirementing with it a bit, using a mic, I found that the tape is recording on highspeed, but playback is very very slow. The pitch knob is set at zero, however I did try a few different settings just to see if it made a difference. I could not tell much if any with any setting. Any help on the setup?
http://www.tascam.com/Products/414mkII.html
There's a link to the users manual on the left. That's probably your best starting point.
http://www.changehiphop.com/images/pics/Signature.jpg Preview of the new Album here!!! Mixing and Mastering services for your project, contact change@changehiphop.com |
Tascam
Thanks for the tip, however I did print off the whole manual, and It did not go into much detail on the pitch knob and how to troublshoot if a problem exists.
hi, i got one of these machines with the opposite problem.it played back too fast. if you open it up theres a small white dial beside the pitch control.this can change the playback speed also.could help.if not there is a bunch of resistors. i found that if i bypassed one using a small piece of wire the problem was fixed
Tape speed has been a problem since they invented cassettes! Hopefully you didn't spend much on the 414!
| help w/ effects during mixdown (tascam 414) | sunday_morning | Mixing / Mastering | 3 | 01-23-2007 20:42 |
| tascam 488mkii portastudio | centroid01010 | TASCAM User Forum | 17 | 12-10-2004 14:55 |
| tascam 414 vs. tascam 414mkII | acetylene | TASCAM User Forum | 1 | 09-15-2004 03:42 |
| Tascam 414 Newbie Here - Effects? | Pepper249 | TASCAM User Forum | 27 | 01-02-2003 11:53 |
| Should I buy the Tascam 414 portastudio | WhitChocolate | TASCAM User Forum | 8 | 02-29-2000 22:30 |
