Back wall...diffusion or absorption?
Most of you are familiar with my little project by now, but for those who aren't here's a recap:
**I have one room for tracking and mixing **Stand-alone building of concrete block structural walls, wood rafter roof with Hushboard and a sheetwood finish, decoupled 5/8" gypsum interior walls, decoupled concrete floor slab on grade, pitched ceiling **Interior dimensions are 12'x13'-6" **Behind the mix position (area I am facing) I have a 4'x6' area of Auralex 'Metro' series 2" foam **Corners behind the mix position (area I am facing) I have (2) MiniTraps bass traps in either corner about halfway up the height of the corner with (2) more planned for the corners on the rear wall **Every 2' on center I have a 2' wide 'stripe' of Auralex 2" wall to ceiling For talking volumes and singing volumes (all I have done until I finish moving everything in and hooking everything up) the previous echoes (pre-acoustical treatment) are no more....it sounds 'controlled' at this point, not really any echo anymore even when I face the untreated back wall and sing. Given this info, any preliminary advice of whether I would be better off putting some absorption at the back wall or diffusion (I'll be purchasing two more traps for the corners, but am curious about the rear wall surface)?
My girl there are just some things that aren't done...like drinking Dom Perignon '53 above the temperature of 38 degrees Fahrenheit |
I believe that unless you are 8 to 10 foot away from the back wall diffusion may not help you. Diffusion needs some space for the scattered image to not sound like hotspots.
Absorbtion would probably be better. I know you run the risk of too dead a sound (perhaps) but I remember reading that small rooms often are not good candidates for diffusors. ( I could be wrong)
Tom Menikos T-Mix Studios Mansfield Texas WWW.tmixstudio.com |
So absorption is the way to go on the back wall. In the 12' width of the back wall (remember I have a pitched ceiling that peaks in the middle of the wall) and with one RealTraps MiniTrap at either corner, any suggestions for the middle as far as pattern? Should I build the rear absorbers at the standard 2'x4' insulation dimensions, or cut the 703 into 2' squares and checkerboard across the wall? Probably quite a few possibilities here. What would LOOK cool, imo, would be to cut the rigid fiberglass lengthwise into 1x4' pieces framed out and then have a series of those every 12" o.c. or so across the back wall.
Any suggestions are appreciated. but if it is 6 of this/half dozen of that, and it doesn't really matter as long as there is a good amount of absorption on the wall, then I'm going to have a little fun with the dimensions and shapes, maybe.
Cheers, Otto |
| Help me - Building a New Studio - Advice for Sound Isolation | newatthis | Studio Building & Display | 20 | 07-11-2006 09:44 |
| where to place foam ? | alecmcmahon | Studio Building & Display | 5 | 11-20-2004 21:36 |
| I wanna built a studio!HElp required | 11miles | Studio Building & Display | 72 | 11-03-2004 14:04 |
| Studio wall construction | Chadwick | Studio Building & Display | 5 | 06-16-2003 22:15 |
