Old 02-01-2007
Nate74's Avatar
Nate74 Nate74 is offline
HR4FREBR
Nate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond reputeNate74 has a reputation beyond repute
Clouds or Primary Reflection Point???
Currently I have 2 2"x2'x4' bass traps on the ceiling above my mixing area, and only a 2"x2'x2' on the wall (primary reflection). Would I be better off moving the over-head clouds to the primary reflection wall?
I've thought about building some more traps, but I wouldn't need a full bundle and my local source only sells 703, 12 sheets at a time. So I'm trying to get by with what I have.
Dogman has the best Avatars ever.
Old 02-01-2007
bpape's Avatar
bpape bpape is offline
Acoustic Designer - GIK
bpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond repute
I'd leave it the way it is - but if you expect the cloud to do bass absorbtion, it needs to be at least 4" thick.
Bryan
I am serious... and don't call me Shirley
GIK Acoustics
Old 02-02-2007
Nate74's Avatar
HR4FREBR
Thanks. Easier that way, but now I'm wondering if I wouldn't be better off taking the two 2" clouds and making one 4" trap. I'd loose surface area but gain bass absorption.
If it matters. I currently have 5 4"x2'x4' traps. 3 are in wall/wall corners and two are in wall/ceiling corners.
Old 02-03-2007
bpape's Avatar
Well, that's a tough call if you're stuck with a fixed amount of material. The real answer is that you need to do both. I'd say the decision would depend on the overall decay time right now, what frequencies you're having issues with, and what specifically is causing those issues.
Bryan
GIK Acoustics
Old 02-03-2007
Nate74's Avatar
HR4FREBR
Good point. I'm considering posting a thread and asking if anybody in So CA wants to go halves on a bundle of 703 with me. I really would like 6 more sheets. That way I COULD do both, double the thickness and keep the surface area. I've also considered using Safe'n'Sound from Roxul which I can get considerably cheaper than 703 and maybe even at a smaller qty.
Of course the more bass traps I add to my already small and cramped bedroom studio, the smaller the room seems to be getting
The Famous Point of Diminishing Returns dobro The Rack 52 12-04-2005 12:44
Bass cut-off point? ::: Badtz Mixing / Mastering 16 05-25-2002 08:32
Using fundamental frequency as rolloff point UberGawkman Mixing / Mastering 5 04-06-2002 21:17
Point to Point III on ProRec CMiller Recording Techniques 12 12-20-2001 15:56
