Old 01-29-2007
SMC Productions's Avatar
SMC Productions SMC Productions is offline
Total Addicted GearSlut!
SMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond reputeSMC Productions has a reputation beyond repute
Tracking Room Ceiling Question
I'm finishing up my new Tracking Room, and have a question about the ceiling. The room has 13 foot ceilings, to start. I have lots of 703 panels, and VERY thick corner treatments so far, and the room sounds pretty sweet already.
The ceiling is 'made' from 7/16 OSB, with R19 insulation on top, and 2x6 'exposed' beams for frames underneath. I want to fill in the 'exposed 2x6 frame with another layer of R19 and use again the 7/16 OSB for a 'finished' ceiling.
Now to the question, as you have the background. Should I 'strip' the paper vapor barrier off the R19? Should I just use 1x slats, instead of the OSB and space them for added treatment?
TNX in advance!
Calcitra Clunis
http://smcproductions.org/smclogo.gif
Old 01-29-2007
Myriad_Rocker's Avatar
Myriad_Rocker Myriad_Rocker is offline
Registered Text Offender
Myriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond repute
Good question. It's beyond me, that's for sure.
You might try posting this question over at www.johnlsayers.com as well.
Myriad Rocker
My Web Design/Production Company: Myriad Productions
My Band: Black Leaf Clover
Originally Posted by theblackBay View Post
I’m currently "one" of the best song writers in the world
Old 01-29-2007
Obi-Wan zenabI's Avatar
Obi-Wan zenabI Obi-Wan zenabI is offline
Force of Nature
Obi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond repute
if you're finishing the ceiling as you describe, then the paper backing shouldn't matter all that much.
You'll still have HF reflections happening off the ceiling, though. One option is suspended ceiling under the beams. Then you can play with your room's sound by switiching out various materials in the 2x2' squares. Auralex makes those accoustic couplers if you wanted the insulation above to suck up more bass.... lotsa stuff to do that way.
just some inexperienced musings, though...
my ceiling is only about 7'2"... you lucky so and so!
Drop ceiling tile options? the7trumpets Studio Building & Display 4 08-10-2009 03:16
Alan... No Stephen Paul Mic? DJL Microphones 249 07-27-2007 23:47
Suggestions for improving tracking room? andyhix Studio Building & Display 7 01-19-2007 08:51
tracking drums, what sort of room? drummersteve Recording Techniques 20 04-10-2006 16:01
Thanks! and an explanation of sjoko's control room (long post) sjoko2 Studio Building & Display 5 03-13-2001 03:32
