Old 01-24-2007
Seeker of Rock's Avatar
Seeker of Rock Seeker of Rock is offline
InLovingMemory..EZ_Willis
Seeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond repute
Wall treatment....symmetry question
So along the mixing axis of monitors, in my case the longer axis of the room, I understand walls should be the same angle coming off of the front wall behind the board, which my dull walls are a standard 90 degrees from the front wall and run parallel to one another.
HOWEVER, does the same theory apply toward treatment from side to side? I have a situation where I would REALLY like, and at this point need, to place treatment between the MiniTraps in stripes not quite across from each other. The traps are not a problem, obviously, but where I placed wall to floor 'stripes' of foam on one side is not where I need to place them on the other. Is this bad?
edit: distance between the two walls in question being treated is 12'-0"
My girl there are just some things that aren't done...like drinking Dom Perignon '53 above the temperature of 38 degrees Fahrenheit
Old 01-24-2007
Seeker, you cool cat. You're talking to yourself online again. What you have no friends here
Alright, I feel sorry for you, so I'll try to help you out in your predicament. Well, first I would go into your room, look to either side of your future mixing position, and see where the wall treatment would position itself. You probably want, at least at the mixing position, all things to be equal as possible on both sides to maintain a true image from side to side (read 'ear to ear') so you can truthfully maintain an honest stereo image. Now there may be factors along the way that prevent this all the way back, but regardless, I think it would be prudent to maintain this symmetry down the sides of the walls, even if cosmetically it doesn't fall directly on the side of say, oh, a door or a lightswitch. That is my advice. No go get'em tiger!!
Old 01-25-2007
bpape's Avatar
bpape bpape is offline
Acoustic Designer - GIK
bpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond repute
Patience seeker. People do have other things to do. Sometimes it takes more than an hour...
Symmetry left to right from the front wall back to the mix position is very important IMO. The only exception is potentially a slight shifting of the mix position and monitors say 6" to one side to get out of the width modes of the room.
Bryan
I am serious... and don't call me Shirley
GIK Acoustics
Old 01-25-2007
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
Seems like Ethan recommends that the treatment in the rest of the room be staggered so that there is a hard surface opposite the treatment.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 01-26-2007
Uh oh, then I was giving myself bad advice. Crap, I thought I had read just the opposite on Ethan's site, or seen a layout schematic or something. Oh well, no use crying over spilt milk, opposite wall to wall the treatment is. It is the 'Metro' model of foam which, according to Auralex, possesses some diffusive properties due to the shape. Not sure that that makes a lot of sense, an absorbant being a reflector, but oh well. There is only 2' between 'stripes', so hopefully everything works out optimally.
bpape, appreciate your wisdom and advice throughout the different posts, though your sense of humor seems to be a bit under par....or maybe my attemped humor is not up to par. I have been away from the Cave as of late, so I blame it on that if it's me.
Old 01-27-2007
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb
As far as I know I never said one way or the other.
I asked an expert friend of mine about this once, Wes Lachot, and he said he favors symmetry over all else.
--Ethan
The acoustic treatment experts
Old 01-27-2007
apl's Avatar
apl apl is offline
Stand Up Comity
My bad, perhaps then.
Maybe that had to do with diffusors.
My tunes. Thanks!
NB
DA BEARS!
Old 01-27-2007
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Good thing...I'm all about symetry and my wife hates it! Even numbers, even items and symetry. 3 times 111 is 666. Proof that odd numbers are evil. And one more thing...don't step on cracks...it's bad luck and wash your hands...often, oh, and don't say words that rhyme with time...oops I just did. Oh no! I've got to go now.
She's not the boss of me
Old 01-27-2007
apl's Avatar
apl apl is offline
Stand Up Comity
Originally Posted by punkin
3 times 111 is 666.
Your calculator requires service.
My tunes. Thanks!
NB
DA BEARS!
Old 01-27-2007
IronFlippy's Avatar
IronFlippy IronFlippy is offline
Dedicated To My Member
IronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond repute
His calculator is the devil!
Symmetry is the way to go, according to one of my textbooks.
I can't listen to that much Wagner. I start getting the urge to conquer Poland.
Old 01-27-2007
punkin's Avatar
My momma sez
you mean evens is evil too?
  #12
Old 01-31-2007
[QUOTE=punkin]Good thing...I'm all about symetry and my wife hates it! QUOTE]
So there is one who likes even numbers in the marriage and one who doesn't. Sounds like a doomed situation to me. Sorry to hear that, man.
  #13
Old 01-31-2007
IronFlippy's Avatar
The deal with side to side symmetry is that you don't want reflections from one speaker getting to you before the other. This doesn't matter if you're mixing in mono, but in stereo and especially surround, it screws with your perspective of the "virtual stage" created with panning.
  #14
Old 01-31-2007
punkin's Avatar
[QUOTE=Seeker of Rock]
Doomed after 25 years. Wait till I break the news to her. She's gonna smack the math skills outta me
  #15
Old 02-01-2007
Make sure she smacks you with both hands, not just one
  #16
Old 02-01-2007
I kind of played the scenario through my head and thought it would be something like that. Thanks for the input everyone
Now, time to post the diffusion or absorber on the back wall thread.
  #17
Old 02-01-2007
bpape's Avatar
Absorber. Your room isn't deep enough to make diffusion effective.
Bryan
GIK Acoustics
  #18
Old 02-01-2007
apl's Avatar
apl apl is offline
Stand Up Comity
I just use my forehead.
My tunes. Thanks!
NB
DA BEARS!
  #19
Old 02-02-2007
I've been wearing a light beard for about a year...I guess that could work in my favor as an absorber
  #20
Old 02-02-2007
Bryan
Thanks Bryan. That's the second vote for non-diffusion. I understand diffusion works better in larger spaces, but there is a rumor that it expands sound in smaller spaces giving them a larger spatial character. Any thoughts?
Currently I have the Auralex 4'x6' in front of the mix position. I'm considering more fiberglass panels either at the rear wall or in front of the mix position, the latter that would require moving the Auralex from in front of mix to the rear wall. Fiberglass would obviously do better at absorbing, so any thoughts on which position (front wall vs. rear wall) would benefit from the deeper absorption, or they need about the same amount?
  #21
Old 02-02-2007
bpape's Avatar
Well, the problem is that the absorber in the rear does double duty. It not only helps with general reflections and decay times, but it also should be thick enough and dense enough to act as a bass absorber. Almost all rooms have a null that is caused by bass reflection off the back wall and is calculated based on the distance from the rear to the seated ear position.
The Auralex foam isn't going to give you bottom end control though it's fine for reflections.
Bryan
GIK Acoustics
  #22
Old 02-02-2007
RICK FITZPATRICK's Avatar
RICK FITZPATRICK RICK FITZPATRICK is offline
Been Here, Posted That
RICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond repute
Seeker, watch for my new thread ...Rear Wall Options..
fitZ
alright breaks over, back on your heads!
RC in a home studio - construction question adam Studio Building & Display 9 04-01-2004 12:14
Studio wall construction Chadwick Studio Building & Display 5 06-16-2003 22:15
parallel wall question jimistone Studio Building & Display 5 06-05-2002 17:02
To All Design Guru's - Parallel Wall question scuppari Studio Building & Display 4 05-29-2002 14:57
Tracking room roof treatment sjoko2 Studio Building & Display 1 03-12-2001 11:59
