Preamp mod
I've got two Bellari Rp220's and i'm wondering if there are alternate tubes i could use, or simple mods to alter the sound.
I like them, wondering if they can be better ![]()
many people come to me and they say hey....... |
The easiest would be to replace the output opamps for something decent, like an OP275 or a Burr-brown OPA2604.
A little more expensive and slightly trickier would be to replace the cheap, piece of shit transformer with a Jensen JT-115K-E. This would yield, by far, the greatest improvement. There are others you could try, but these are the "easier" ones. . |
thanks
What makes replacing the transformer "trickier"? Is it a probelm with physical form factor or is there something else involved? G. |
Brendan, if I'm not mistaken, I believe the opamps are socketed, so replacing those would be a breeze. Just yank out whatever's in there, and you can try out several different opamps (just pop 'em in) in it's place until you find one that grabs you. . |
i would imagine the transformer mod involves a bit more? soldering and all that fun stuff?
http://focus.ti.com/docs/prod/folder...topsidemarking i'm wondering if i can choose one or many and i won't run the risk of damaging the unit. I'm not well versed in modifying audio gear
Chessrock, any tips to mod the behringer T1953? i ordered opamps for the bellari and would like to change out the behringer.
i don't suppose you know of any tutorials to swap out the transformers?
You're not going to damage anything by trying out different chips. Just make sure to touch them, periodically, to see if they overheat. If they get really warm after a few minutes of use, then chances are it's oscillating and you can pretty much disregard it as an option.
I don't know much about the Behringer, but chances are it's surface-mount, which would mean a much trickier mod which should probably be peformed by a more skilled tech. If, by some strange chance, they happen to be socketed, then the chip you'd want to look for is the SSM-2017, I believe. You'd want to swap that out with something along the lines of a Burr-brown INA217 or an Analog Devices SSM-2019 ... or one of the newer THAT chips. As for the transormers, I can't think of any tutorials or anything. You can pretty much just look at it and tell where everything goes, though. Not really complex stuff ... but if you have a buddy who gets in to electronics it might be a good time to give him a call, just in case. . |
| Preamp for Marshall MXL V57M? | crossroads | Newbies | 1 | 12-30-2005 16:53 |
| preamp comparison | Peetr3 | The Rack | 62 | 12-28-2005 17:01 |
| A couple of mic preamp questions for you whizzes | boechler | The Rack | 6 | 11-25-2005 20:46 |
| Mod a cheap preamp | sk8ingsnowman | The Rack | 1 | 08-18-2003 20:58 |
| preamp vs. dynamic mic | jungkang | Microphones | 7 | 08-02-2001 21:10 |
