I have an ESP f-100fm, or something like that. It has a bolt on neck, and I was wondering. If I, for some reason, wanted to replace the neck of the guitar, would I be able to? It is a bolt on, so theoretically(sp?) couldn't I unbolt the neck I have and then bolt on another neck?
Also, where would I find a neck to replace my neck with? Thanks -Elliot |
yes, you could replace the neck. you'll likely have to measure the bolt pattern and neck pocket. i like warmoth necks. i don't know if they have a direct fit for your guitar. you'll have to measure and find out.
Theoretically, yes. HOWEVER, that would depend on getting a neck which actually fit the guitar, which is not at all a sure thing. Most manufacturers have their own neck heal designs, and even within some manufacturers, there are differences. You can not, for instance, just swap out the neck from a Tele onto a Strat. You would need to do some modification to either the heal of the neck, or to the neck pocket on the body. The easiest thing is to get an OEM neck from the manufacturer, but that is not always easy to do. Light "Cowards can never be moral." M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children." -Aqeela Sherrills http://www.theforgivenessproject.com/ |
![]() -Elliot |
Not if it's a 24 fret neck, they don't. You would need a three fret extension, which wouldn't work at all. Light "Cowards can never be moral." M.K. Gandhi
They are still probably not the same size, for a variety of reasons. First of all, they probably start the heal at about the same place as on a Fender neck, so it is probably a longer heal (I don't know this for sure, but it is true of many brands), plus, the neck is probably wider at the end of the heal than the heal of a Fender. More to the point, even if the heal IS the same shape, it isn't really because the scale length would be in the wrong place. But, as you say, it wouldn't work either way. Light "Cowards can never be moral." M.K. Gandhi
| FS: 1961 Fender Statocaster Neck | bwindsor | Free Ads for Music / Recording Equipment | 4 | 03-14-2006 10:15 |
| Acoustic guitar neck cleaning | RideTheCrash | Guitars and Basses | 29 | 12-18-2005 00:07 |
| Set Neck Vs. Bolt on Neck | capnkid | Guitars and Basses | 16 | 11-16-2005 17:22 |
| Putting a neck on a nameless guitar... | noiseportrait | Guitars and Basses | 5 | 04-29-2004 16:17 |
| Humbucker for your neck | GT | Guitars and Basses | 5 | 07-14-2000 23:19 |
