Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 01-21-2007
rockabilly1955's Avatar
rockabilly1955 rockabilly1955 is offline
Dedicated Member
rockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond reputerockabilly1955 has a reputation beyond repute
Need Intonation Help
I have a Ibanez Artcore hollow body and am having trouble with tuning/intonation issues. I have found that the problem is in the 3 hight strings with the high E being the worst. They are in tune in the open position but sound pretty off in the 12th fret. They have a dead, ping like sound and also are showing to be pretty flat on my tuner. The difference in bridge height from the low E to the high E is pretty noticeable too. Should there be a big difference there?? What can i do to try to get a better intonation?? Thanks
Check out these sounds
http://www.soundclick.com/bootlegrockers
Old 01-21-2007
Jouni Jouni is offline
1K Silver Member
Jouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond repute
I'm no expert, but sounds like your bridge has peen set up weirdly.. Did just get that guitar?.. has someone adjusted the bridge?..
Have it set up by a shop, that's the easiest solution.
I had a talk about intonation of my bass with some elderly geezer, about a proper tuning-meter to set up intonation, and he said that you don't need one!?
Said he can show me how it's done with harmonics!.. Gotta check out that..
\m/ WAR OUT!! \m/
Old 01-21-2007
Dedicated Member
i've actually had it for over a year now. It sounded pretty good right out the box when i first got it. It might be that it has just gotten totally out of whack with time and all the playing? ijust started noticing the problem a few months ago
Old 01-21-2007
guttapercha's Avatar
guttapercha guttapercha is offline
Lovely Lad
guttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond repute
The dead ping sound is the key diagnostic feature for the string making contact with a fret higher than the fret that you are putting pressure on. At best this could mean that the bridge saddles are adjusted too low. At worst, it means that your neck needs to be reset.
Old 01-21-2007
Dedicated Member
good tip. I checked and it looks like the 3 high strings, especially the high E are touching the the frets from about the ninth fret on, and pretty noticeable. Though the low strings look like they touch too, its not as bad. I will try to raise the high string side of the bridge, as i mentioned that it seems very low compared to the low string side of the bridge. I know there should be a difference but probably not like mine
Old 01-22-2007
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
In all likelyhood, your top has sunk a bit with the heating season. Pretty typical. You would be well advised to make yourself a soap dish humidifier for your guitar.
Light
"Cowards can never be moral."
M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children."
-Aqeela Sherrills
http://www.theforgivenessproject.com/
Intonation (I think) problem with my g string. michael_lifshit Guitars and Basses 6 05-22-2006 17:01
Acoustic Intonation Tips GoldFalcon Guitars and Basses 2 09-17-2005 13:33
Intonation GoldFalcon Guitars and Basses 7 08-27-2005 08:13
Restung my bass and set the intonation,,, what a difference. badgas Guitars and Basses 10 09-27-2003 19:56
A tuning type problem, maybe intonation? ZoSo58LP Guitars and Basses 9 06-29-2003 18:27
