Drum Triggers
What will I need to trigger my kick and snare? And I mean everything I will need!
I send my drums into a Tascam tm-d1000>RME HDSP 9652>Logic, if it matters. |
That depends on what you plan on triggering.
1. You will need triggers, the actual things that you clamp to the drums. 2. Cables 3. A. a drum brain to play the sample when you hit the drum OR B. you plug the cable into your interface and record the signal from the trigger, then replace it with drum samples using Drumagog or something else. OR C. you use a drum brain to turn your hits into midi info that can play samples in a sequencer.
Also, I am a midiot. It would be helpful to avoid midi, but if it's the better route to take, I'd be willing to learn, as long as no one found out. And if you'd be so kind, could you provide names or links for the trigger and brain. |
Always (in my opinion) copy the audio track and then use Drumagog, I know it can go without saying, but you may want the flexibility back, or find that the trigger didn't translate as well as you thought it would. Good luck.
"How you gonna drink yo Vodka!?" - Jason ======= "Pre-CBS Fender corporate buy-out." "I'd raise the bridge, file down the nut, and take the buzz out the low E." "God, I love this woman." |
http://www.zzounds.com/item--ALEDM5
god... firstly, http://www.musiciansfriend.com/produ...ger?sku=449932 http://www.musiciansfriend.com/produ...ger?sku=449931 then http://www.musiciansfriend.com/produ...ter?sku=442374 then http://www.musiciansfriend.com/produ...ble?sku=361708 then http://www.musiciansfriend.com/produ...ace?sku=701379 and thennn http://www.musiciansfriend.com/produ...age?sku=709985 if you an interface, omit the ubs adapter. also, this is for use inside a DAW. DFH runs as a plugin technically,
GFCG Member: 000 029 F**k Your Scene. |
I haven't tried this but it looks very interesting to me: http://www.alesis.com/product.php?id=102 That and a couple of triggers/1/4" cables would have you up and running. You would have multi velocity sampling and could upgrade to a better software/sample package later if you're not happy with BFD lite. |
Firstly, thanks for the info. I don't necessarily think that I "should" be using triggers, I just think it MIGHT save some time and improve my drum sounds. I record only myself. My studio is in my garage and it's kind of small, so I'll usually set my drums up to record tracks for a few tunes that I wrote on guitar, then tear them down to work on everything else, i.e. guitars, vocals, etc. . My drums will be tore down for a month or two at a time, and drums are not my primary instrument, so tuning is time consuming. Plus, the room that I am recording in is less than stellar, to say the least. And my hits are not consistant. I'm all over the place on the drum itself, and the volume varies, too. I'm just looking at my options. |
And thanks for the links! |
#12
If you dont need to do it live then just get Drumagog and some very cheap dynamic mics. If you want to do it liave then you could get a cheapish MIDI drum kit and load in some meaty drum samples.
![]() Eck |
#13
Can you run a lot of effects at once on your set up, Farview?
#14
#15
I'm running an older AMD 2600 with a gig of ram and it gets squirrely sometimes. My other computer is a 3.4ghz with 1 gig but it's Windows media edition so it never worked too great with my audio programs/hardware. So your UAD card is basically the resource host for your plugins, right? I was wondering about those, do they only host the plugins you buy with them, or can you like send route your other plugins to use that UAD processor? Sorry to hijack the tread, willis.
#16
The UAD card only works with the UAD plugins, but they are the best sounding plugins ever.
#17
#18
I recently recorded King Mixer, a local band, and for a variety of reasons I couldn't get a decent kick sound on the inital capture. So I decided to replace it in the mix. I ended up using the recorded kick as the trigger impulse into my Alesis DM5. I stuck a gate with a really quick release time on the original kick and used a volume envelope to even out the hits. I then sent that signal into one of the trigger inputs of the DM5, and tweaked the threshold level in the DM5, then recorded the sample kick to a new track. It worked very well, IMO.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
#19
#20
#21
You don't need to buy triggers to trigger samples.
If you have a clean close mic recording of snare, on its own track, and kick on its own track, you should be okay.
Insect Massage Therapist HUGE sound generation & capture facility http://www.toddejones.com |
#22
I don't understand drum triggers that well, but I have a yamaha dtxpress3 and this made me wonder if it was possible to do what you just described with that. I realize that the pads on electronic drums are called "triggers" but can you just route any old 1/4" signal in there? |
#23
#24
Right on! I was planning on "souping up" the live drums (gating, compress) to get rid of extra noise and length in each one (mainly snare and bass like ez_willis was talking about) before I send it in brain.
This is like a new toy for me! WOOOHOOO |
| Are drum triggers cheating? | Greg_L | Drums and Percussion | 25 | 01-24-2007 15:45 |
| bad drum sounds | noground | Recording Techniques | 20 | 08-26-2006 08:56 |
| Drum Triggers | M Havlen | Drums and Percussion | 12 | 01-27-2004 06:47 |
| Triggers & Drum Machines | Gear_Junky | Drums and Percussion | 5 | 07-21-2000 06:17 |
