Old 01-15-2007
drewz0r drewz0r is offline
Newbie
drewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond repute
Drum edits... noticeable?
Recently, my friend and I recorded lots of drum takes for an EP we are working on.
In order to get the best possible arrangement I had to fuse together different bars of different takes and different fills. (etc) The adjustments are not painfully obvious, but they are noticeable. My question: generally, will the addition of guitar, bass, and vocal tracks help cover up drum edits?
Thanks,
Drew
BTW, this is my first "real" project and I'm stoked.
Old 01-15-2007
LIMiT LIMiT is offline
Senior Member
LIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond reputeLIMiT has a reputation beyond repute
Hey man...
I would suggest you get the drums laid down right in 1 take.
The most important steps in recording are:
a good song
good players playing the song
good instrument
well tuned instrument
room
mic, mic pre's, converters etc
Drums are the foundation on which a good mix is built. You want the drums to be as spot on as possible, so when everyone else tracks to them,..the same 'emotion' and 'flow' is carried through the takes.
If there are drum edits that are noticeable, this will effect every player playing to them. (If you're editing full bars and have already tracked everything else...you're in for some major headaches).
Editing drums is common, but it's more moving or muting a kick or snare hit here or there.
Can you give us a clip of what you're working on?
-LIMiT
Put the mic up and hit record, simple as that...
Old 01-15-2007
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
It depends on the drummer and engineer. If both are good, you wont notice anything even just drums solo'd. I have punched in drum parts at times and if done properly it is seamless. As said in post ,try to get them right the first time but that isnt always the ways it works out. I have many times done full kit punch ins manually. I have the drummer play to existing track and when I feel it is a good point I punch him in. Usually on a down beat or strong cymbal hit.
Jim
People always seem to embrace the future then long for the past
Old 01-15-2007
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Take LIMIT's advice, bro.
If they show, you have to assume they'll show even with other instruments supposedly "masking" them. You'd hate to have people noticing room sound cutting in and out, etc...Someone listening through a good set of headphones would probably notice, at the least, something "wrong" with the track....Even if it's not noticeable right away to the naked ear, it will effect the feel of the tune, I think.
Old 01-15-2007
RAMI's Avatar
www.ramirami.com
I agree.
I was answering based on this statement:
Old 01-15-2007
Newbie
http://drewconley.googlepages.com/Snare_DrumSolo.wav
Here is a drum solo/fill section.
This is just a bare overhead track panned center. Obviously the real session has a bigger sound. This is the most common example of the editting I am referring to.
Thanks for the replies!
Old 01-15-2007
Senior Member
I was basing my response to the fact that the poster stated this is his first project, so learning the *best* way to go is to get it all in one take.
**Having trouble listening to the clip you posted. Might be just me**
cheers,
-LIMiT
Old 01-15-2007
Newbie
I appreciate the tips regarding the all-in-one-take method, but redoing the drum tracks is not an option for us right now.
With that said, I would like to change the topic to "What can I do to HELP these fused drum tracks?"
Trust me, if I had more reliable band members who were in to this project as much as I am... we wouldnt be having this discussion.
No worries though, next time I will definatly use the one-take method.
Old 01-16-2007
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
I agree that drums should be done in 1 take, although sometimes it is a hard feat if the song is particualrly tricky.
Ive done alot of drum editing, using a part here, a part there to peice together flawless drums. It wasnt a quick job in the slightest, but I suppose it was worth it to get the drums sounding alright.
There are times when edits in drums just arent possible IMO. Say you have a snare hit out of place or the snare hit is a bad hit, and you move the hit or replace the hit. If there is alot of hat bleed then sometimes it wont sound right. Ive done things like copy and parts from OHs at one part of a song then pasted them in another part of the song to make the drums sound flawless.
Eck
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 01-16-2007
ecktronic's Avatar
At 5 seconds I can hear the cymbals stopping suddenly then starting again. I beleive this is a edit you did. I dont think it will be a big problem when in with the rest of the band, but you can always use the OH technique I explained in my last post.
Eck
CRYSTAL MIXING
MY BAND
Old 01-16-2007
MessianicDreams's Avatar
MessianicDreams MessianicDreams is offline
Throbbing Member
MessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond repute
As suggested, it's best to get drums down perfectly in 1 take.
But we all know, sometimes that just isn't possible.
For best edits, try zooming in as close as you can on the wave form. do any edits at zero crossing poins on the waveform, or as close as possible. Fadeouts and crossfades are very useful in taming sounds being cut by the edit points.
There are 10 types of people...those who understand binary and those who don't
My humble home studio!
My Choons
My DIY Broadband absorbers thread!
Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack
  #12
Old 01-16-2007
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
Yes, crossfades are your friends. On drum edits, don't watch the monitor as you evaluate the edit. It should be hard to detect the edit with the drums solo'd before you result to full mix masking. Experiment with different edit points. The place you first think it should go is rarely the best place. Never cut off a cymbol as it rings out - dead give away.
Regards,
RD
http://www.myspace.com/twentysevenmoons
  #13
Old 01-16-2007
RAMI's Avatar
www.ramirami.com
Great advice above, starting with Eck's post a few back. I definitely strive for a one-take drum track. But I punch in if I need to. You just need to make sure your punch-in point is clean....eg: Long enough after the decay of a cymbal crash, etc...
And give the drummer a good pre-roll so he can get into the groove of the track he's going to continue.
Kick Drum Miking Question zackformula Microphones 18 06-22-2006 07:28
Unusual problem with mic bleed... name_goes_here Drums and Percussion 8 08-15-2004 18:16
3 Drum Map Queries ebitda Cubase User Forum 2 07-07-2004 13:32
Cheap drum triggers/pads Lopp Drums and Percussion 7 04-09-2003 22:58
how to get that loud,low-end,kick drum click sound step by step right here ZEKE SAYER Drums and Percussion 31 05-20-2002 15:55
