does anyone have a recording of the 60 hertz hum?
i get a low pitched noise in some of my recordings but i don't know if its the 60 hertz hum, has anyone recorded it as reference for noobs like me? and if it is, how do i get rid of it? i read an article saying i should remove electrical wires, and not have my cables run parallel to it, but i haven't tried it yet..any ideas?
thanks, iovaykind |
I don't have a recording, but there's a couple of ways you can determine what you got. First would be to use a parametric EQ band, set it to narrow width ("high Q") and using the frequency control, slowly sweep through the low frequencies until the sound is knocked down. Read your frequency setting at that point and it'll tell you the frequency of the hum.
The hum may have more than one frequency component; e.g. there may be harmonics in there as well. A second method which would help ID it in this regard is to use a frequency spectrum analyzer. Most DAW software comes with a plug for this. But there is also a free one available from Voxengo called "Span" (www.voxengo.com). Play back a quiet part of the track where the hum is relatively isolated (e.g. the few seconds at the beginning of a track before the instrument starts) and look at the analyzer display for ominous bumps in the frequency curve. Common causes for a 60Hz hum are a bad ground or a bad cable somehwere in your signal chain, proximity to neon or florescent light fixtures, or audio cables running close to and parallel to AC cables. HTH, G. |
or if you are in a basement, like i am, the walls might have been slapped up all messed up, and the electric might have been ran like crap, and more problems there, possibly..
GFCG Member: 000 029 F**k Your Scene. |
Dimmer switches on the lights are usually the worst offenders.
![]() iovaykind, try taking a mica cable and crossing it across an amp power cable or something, you may hear it there. That's the only experience I accidentally had with it.
"How you gonna drink yo Vodka!?" - Jason ======= "Pre-CBS Fender corporate buy-out." "I'd raise the bridge, file down the nut, and take the buzz out the low E." "God, I love this woman." |
Art |
I do but it is out being mastered.
"Tascam, Fostex or Studers don't make hit records...........people do" MCI2424 - 2007 |
Tom Waits.
I don't have a recording of 60hz hum, but for those who do: Can you recommend a condenser mic that would be good for recording 60hz hum? something for under $100?
Anybody know how to take the vocals out of a 60hz hum?
#12
"How To Take the Vocals (Out Of A 60Hz Hum)" Recorded in 1972 by The Homewreckers and released by ABC/Dunhill as a "B" side to their top 300 hit, "What Compression Ratio Do You Use, Baby?" G. |
#13
cubase
my cubase LE has something called a grungilizer. You can set it to add a 50Hz or 60Hz hum. It's for making your recording sound like an old record.
maybe you can find the grungilizer as a plug in and download for not too much $$$. (Assuming you're recording on computer) and no, I'm not making this up. Obi -Wan yrraB evaD [wow. my hundredth post. woot.] Last edited by Obi-Wan zenabI; 01-22-2007 at 11:58.. Reason: pride |
#14
#15
60-cycle hum or 60-second hummer... whatever works.
| PC recording, not for the fence-sitters | Diragor | Digital Recording & Computers | 11 | 02-28-2006 17:26 |
| THE DAVEMANIA COLLECTION Glorifies HOME RECORDING and TASCAM! | A Reel Person | TASCAM User Forum | 32 | 06-19-2005 04:24 |
| Mains Hum? when recording | wilko | Fostex Forum | 9 | 10-27-2004 08:15 |
| THE DAVEMANIA COLLECTION Glorifies HOME RECORDING and ANALOG! | A Reel Person | Analog Only | 3 | 12-15-2001 01:14 |
| Single coil recording hum | Slackmaster2K | Digital Recording & Computers | 5 | 05-23-2000 12:16 |
