Old 01-13-2007
danny.guitar
Guest
Posts: n/a
Room mic
Just wondering if anyone else does this too.
When tracking I usually setup the mic the best I can, and then put a room mic off in the distance about 4 ft or so. I keep the room mic where it is.
I do this for all tracks and use the room mic for realistic ambience instead of reverb because I can't seem to get a good, realistic room sound out of reverb. I usually use it to "polish" the sound instead.
Anyway, I notice this helps to get a more realistic "sound stage" and makes things easier because I can just adjust the level of the "dry" track compared to the "wet" (room) track to bring things back or forward in the mix as opposed to just left and right.
This probably wouldn't work in some recording situations but it's just me most of the time so it works out pretty well. I had a few phase issues when first doing this but if I keep the room mic where it is and record everything else at about the same spot it works pretty good.
I also find it helps to keep the room mic in a dead area pointed at the source otherwise it will just pick up room reflections and sound like shit.
Anyone else do this?
Old 01-13-2007
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Not a bad place to start.
A big part of the deal is to know your recording room, then the gear you plan to use. You're off to a good start and if you like the sound then you're one up on it.
Placement is everything. Try moving the subject, the subject mic and the room mic around and note the changes.
You're working the equipment now...good job.
She's not the boss of me
Old 01-13-2007
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is online now
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
You had me - I was going to say "If the room sounds good, this can be handy" - until the above paragraph. To which I can only reply: .
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 01-13-2007
danny.guitar
Guest
Posts: n/a
G.
The problem is my room doesn't sound good. So I have to put the room mic in the closet infront of a bunch of clothes. Otherwise I just get a shitty sound.
In a deadened area (isolated from all the bad-room reflections) it can give a good sense of proximity without all the shitty reflections.
Maybe in a good room this wouldn't be necessary, but I'm in a small untreated bedroom.
How does diaphragm size/polar pattern relate to mic applications? Chris F Microphones 963 2 Days Ago 16:53
Ribbon Mics With/Without Phantom Power... kidvybes Microphones 16 08-26-2006 12:35
Some random musings from a recent mic shootout . . . chessrock Microphones 38 11-05-2005 21:20
Mic choices for solo grand piano/jazz combo recording in small room Derel Microphones 3 01-09-2002 23:56
NT1 Rode ? Ears Microphones 24 06-27-2000 09:16
