A reasonably priced diffusor for home studios.
I stumbled across these on the web today and judging from the shape they look like they would do a reasonabley good job. And at 30 bucks for 12 square feet they would be a good deal compared with MF charging nearly sixty for a four square foot Auralex T-Fusor.
http://www.mioculture.com/store/pc/v...=2&idproduct=9 |
reasonable priced indeed. i wonder what Ethan thinks of these.
Maybe you can interface with my ass, by biting it. GFCG Member No : 000 015 "It's hopeless. I can hear all this great music in my head, but my stupid hands can't keep up..." |
I really doubt their usefulness. Generally things made of paper, don't do so well for sound treatment. Also, they are probably quite the fire hazard.
The other thing I remember hearing, is that a proper diffusor has varying depths and thicknesses of material to diffuse across the entire frequency range. Those look more like pretty decorations than anything useful. Simon |
i was thinking that too but if it is solid paper it might be heavy enough.
Since these are being manufactured exclusively for wall covering I am hoping that they have had some fire-resistant chemicals or fibers mixed in. Dense cardboard in general is not as flamable as fabric or paper or foam. |
Realistically they may be OK since simply due to their depth and spacing, they'll not be very effective as a diffusor under maybe a couple kHz. At that frequency, the thickness won't likely be an issue. I'm more concerned about the large gap where the panels fit together that appears to be essentially flat.
Bryan |
$720 for a 4'X6' area...hmmmmm, not exactly cheap, but
My girl there are just some things that aren't done...like drinking Dom Perignon '53 above the temperature of 38 degrees Fahrenheit |
i think your math is off a little bit seeker....
from what i gather, it would cost more like 60 bucks to cover a 4'x6' area.
As for the small flat areas I don't think that it is quite necessary to cover ever every square inch, just as with absorbtion. |
i think some of the claims made regarding "standing waves" and such seem dubious. it would be good if they had dispersion information on their products to disclose the frequency range they affect etc... i think the lack of technical information should be viewed as one possible difference between this product and other manufacturers with proper disclosure and realisitic claims on what their product is actually able to do.
I guess the question is, how many home studios would really benefit from diffusion? Since most of us are in small rooms, absorption seems like the better option. Maybe I could use them to cover one side of some gobos if I need a more reflective surface for tracking...
#12
Up high end to end they might be OK to help with the slap a bit as long as it doesn't get in the way of bass control.
As for the flat spot, well, I guess the only way to find out would be to try them. Bryan |
#13
Hell I just may drop $90 on these and give them a try. I have 2 walls with about 60% absorbtion and 2 bare walls in my tracking room. I bet it would be better than having just plain ole drywall. Yep, I'm going to do it. I'll report back how well they work. Maybe a before and after drum track.
http://www.garagerecording.com/images/lava22.gif SELECT W.People FROM tbl_world W WHERE W.Clue = TRUE NO RECORDS RETURNED |
#14
I think you should contact the company and ask them if they have any test data showing the effectiveness of the diffusion, with polar plots etc. Let us know how they reply. --Ethan
The acoustic treatment experts |
#15
#16
#17
#18
You might try mineral fiber for filler behind them. For $30 it's worth a try for someone to do it. (my room's already treated well)
#19
I've got a rather large new control room to contend with, maybe I'll be the little test monkey.
The Jungle... My diggs. |
#20
Oh crap, I missed the 'per 12 sf' in that didn't I? It must have been behind my wine bottle on the screen Now that is a hell of a price if they work.
#21
I called and talked to a MIO rep. The acoutic weave does not have a fire rating. They are simply "paper" He did indicate the tiles could be painted with a fire resistant paint. He did point out that since these are relatively thin panels - the amount of "fuel" (ignitable material) is limited.
They do have fire rated tiles that have a fire rating - for commercial applications - which cost more. I asked if they had recieved any feedback from studio clients. Since this is a relatively new product, they don't have any real feedback and in fact have not yet recieved any actual "inventory" (they expect inventory this month). They are based in Philly - and did indicate a small local studio does intend to try the product (when they get some inventory). I'm not convinced that on a limited basis these tiles pose much more risk than egg cartons, moving blankets or many other "sound treatment" options used in home studios. I don't know if trying to paint them with file resistant paint would be worth the extra cost or effort (you would likely have to first paint with a primer/sealant and then paint with fire resitant paint - a lot of cost and effort). I would not want to cover entire walls with something that is not flame resistant - but for a side of a gobo or a door in a vocal booth - it may be an acceptable risk. I plan to order a 12 pack (I've spent $30 on plenty of other dumb things) to try. If and when I get them and if this thread still has any life - I'll try to post a user comment. |
#22
If they any diffusion characteristics, you can buy them and use it as a jig for
a fiberglass(e.g. hard) model. For 30 smacks it'd worth a try by someone that has time and extra mula. It should at least work minimally for breaking up standing waves in the upper frequency no? which us home reccers have trouble with in the tracking side of things. But is it worth vs absorption? close in cost, but the risk? Mikeh, glad your steeping up to try these out. It would be alot of effort prime and paint, but with a spray gun, it might be less work. But it would up the total cost. Please do post a review on these. T |
| Why the old digital units in some studios? | expatguy | The Rack | 30 | 04-27-2006 22:12 |
| Old studios with amazing gear.....what's the scoop? | LemonTree | Recording Techniques | 1 | 09-08-2005 14:42 |
| Mid priced Drum Set Buying Question | Fusion2 | Drums and Percussion | 12 | 09-23-2004 10:44 |
| the flaming lips, dave fridmann's studios, and synth strings | jimmychan | Keyboards and Sound Modules | 1 | 01-03-2003 22:47 |
| AKG 414 or 2 mid priced condensers? | harley96 | Microphones | 22 | 11-12-2001 07:49 |
