Old 01-09-2007
Jrasia Jrasia is offline
Senior Member
Jrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond reputeJrasia has a reputation beyond repute
Speeding up a Mix....Need Help!
Hopefully someone here has some experience with this problem....let me explain.
A band came in to initially record some demos, liked the sound so much, that they are now considering using the songs for a EP release.
Session was recorded in Nuendo 3, live off the floor, very ambient, heavy stuff. Probably one of the best sessions I had.
Anways, after doing the beds, overdubs, and giving everything a listen at the end of the night, the band later decided that about 4 out of the 5 songs seem 'slow' to them. Not by much, but could use a slight bump to speed them up.
I've never been one to mess around with pitch shift, or play around with plugins, but I'd like to keep these guys happy.
I'm skeptical about doing any speed increase, cause I assume its just going to mess with the whole mix and ruin things. No vocals have been recorded yet, and we'd like to see if its even possible before recording them.
My question is, is there anyway to speed up the temp of these songs without noticable messing up the sound?
Any info would be greatly appreciated.
Jay
Old 01-09-2007
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
well, it's always going to mess with the sound. The better the plugin, the less artifacts you'll here.
I'd bounce/export a test version of the mix as is. Then time compress it where you want it and listen back. But it all depends on how much you speed it up and how well your ear is tuned to hear if any artifacts are created. If you don't hear anything...then go for it!
www.redlabaudio.com
Old 01-11-2007
MessianicDreams's Avatar
MessianicDreams MessianicDreams is offline
Throbbing Member
MessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond repute
i would be tempted to simply re-sample it rather than try to use a time-expansion plug, as this will, depending on the quality of your plug-in, cause some fairly strong artifacts.
so you'll get your faster tempo, but with a slightly higher pitch.
as longas it's only a little bit faster, the tempo change won't cause the "chipmonk" effect on the vocals..
There are 10 types of people...those who understand binary and those who don't
My humble home studio!
My Choons
My DIY Broadband absorbers thread!
Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack
Old 01-11-2007
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
If your using nuendo 3, you should be able to put all the tracks and audio files in 'musical mode', which will tie it to the tempo on the sequencer. So when you change the tempo, everything will stick to that tempo, all the audio files will speed up. The advantage of doing it this way also is that there is no pitchshifting that occurs whatsoever. the disadvantage is that if you speed it up too much it will probly add some artifacts.
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 01-14-2007
Senior Member
Thanks for all the great suggestions. Greatly appreciated.
As it turns out, the songs have mysteriously been playing back at the wrong sample rate.
As I said before, the project was recording in Nuendo, Audiofire 12, 44.1, 24bit.
We played back the mixes at the end of the night, everyone was happy.
Next day, I go to send the band a quick mix down mp3 of there songs, and thats when they started noticing how all the songs were slower.
Even did a mix down to .wav, double checked export settings for sample rate, bit rate...etc.
After trying to figure out why everything is now supposily slower, I noticed that if I changed the sample rate in the projects to 48.0, without resampling the actual audiofiles, everything is now at the proper tempo and pitch. The audio files themselves in Nuendo are 44.1, which is how they were recorded.
How could have this happened? A template was saved in Nuendo for 44.1, 24bit, everything was totally fine during both recording, overdubs, and playback, computer was untoched at end of night, and then all of a sudden all the songs only properly play back at 48.0
Anybody have this problem before?
Theres no way the entire project could have been resampled without me knowing. I've been scratching my head over this, I have no idea how this could have happened.
Jay
Old 01-14-2007
do you have any piece of digital gear that allows you to send clocking information to Nuendo? It could be you had a sample rate set to 48kHz somewhere, despite your session being at 44.1kHz. Then maybe when you turned the clock off, it screwed everything up.
Or it could be something simple as you THOUGHT you made a 44.1kHz session but you didn't.
www.redlabaudio.com
Old 01-15-2007
Senior Member
My clock is set internally, and I have nothing else that could have conflicted with it.
I also reopened the template that I saved in Nuendo and created a new project and sure enough it was set for 44.1, not 48.0.
weird, very weird.
Old 01-15-2007
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Old proverb:
"When you're sure everything is right but it still doesn't work, something you're sure is right is actually wrong."
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 01-15-2007
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
I would tell them ....too frek'n bad. They shoud have got the tempo right at the the first drum track. I beleive it to be crutial for the band to listen to the initial drum tracks to make sure it's at the write speed. I just hate fixing things I guess.
Hey if it sounds good to ya them convince them to keep it.
Old 01-15-2007
Ironklad Audio Ironklad Audio is offline
1K Silver Member
Ironklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond repute
gcapel called it...the band should know what tempo their own songs are supposed to be...and furthermore at least SOMEBODY should be able to notice, while playing, that the tempo is off so that they can do another take, instead of trying to rely on studio tricks to fix it
Old 01-15-2007
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Because you tracked at 48.0
Your Audiofire settings were probably different than your project settings.
  #12
Old 01-15-2007
DAS19 DAS19 is offline
Me, You, And Davey Too!
DAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond repute
My guess as well.
  #13
Old 01-15-2007
Its not a big deal though just export to 48 then convert to 41.
Soundtracs Topaz Project 8 Nick The Man Other Equipment and Reviews 30 04-08-2008 14:02
Can I get the right way to mix or a process I should use to mix correctly. PaulKarate Mixing / Mastering 6 12-12-2005 11:24
Breaks Mix - Feedback wanted. digital_age MP3 Mixing Clinic 0 11-28-2005 14:09
I really need some help with technique. Looking for pointers. Lempface Recording Techniques 17 08-29-2005 17:09
