Another Pro Tools question...regarding tempo.
I've been searching in the manual for this but clear cut answer. Whenever I change the tempo in my session where i have a few audio tracks recorded, it throws off the whole song. Everything becomes offbeat. Is there a way to make pro tools adjust the tracks accordingly when u change the tempo like in Reason or FL Studio?
Hi,
so you've recorded tracks at 120bmp (for example), and are now switching to X bmp? I'm assuming the content is an audio track, and not midi or anything. Unfortunately, the only option you have is time-stretching (plugin) your audio, which changes the pitch of the audio as well (depends on how much you're stretching it). A program like Reason can adjust to tempo changes as all the synths, drum machines etc. are midi and run off the same 'tempo clock' in the sequencer. It's best to find what tempo the song sounds best at, create a click, and record all audio and midi to that tempo. This doesn't mean that the whole song has to be one tempo...PT lets you edit your tempo map as you need to. or record the basic rhythm track as is and how you 'feel' it. Go back to where the start of the first measure is and 'Identify Beat' (cntrl-I in XP, Apple-I in OSX) as 1 | 1 | 0 | 0 . Do this for every beat in succession (ie. 2nd beat 2 | 1 | 0 | 0 and so on). Once you've 'Beat-Mapped' your entire song, the click and grid mode will follow the map you just created. The bpms will change every bar no doubt, as you didn't record to a click. One option from this, during playback, is you can look at the bmps change and find an average bmp to your song, create a click and record everything to that, or see where your song slows down, and adjust the click for this region only...etc. (Essentially Beat Detective) Ran out of time...bands here... -LIMiT
Put the mic up and hit record, simple as that... Last edited by LIMiT; 01-10-2007 at 11:49.. |
| Simple Pro Tools Question.... | newatthis | Newbies | 7 | 06-23-2006 12:50 |
| Pro Tools Digi 001 OR Tascam 2488 | sevendustweb | Digital Recording & Computers | 3 | 10-21-2005 16:06 |
| Newbie pro tools LE 6.0 question | sk8ingsnowman | Digital Recording & Computers | 3 | 05-10-2003 00:13 |
| Pro Tools (888 Interface, SSD, VSD) and the MOTU 2408mkII | pisces7378 | Digital Recording & Computers | 2 | 04-01-2002 04:01 |
