Midi drum newb.
Hello everyone! I was wondering what the best way to record midi drums would be? I'm using a m-audio midi controller, DFH, and Sonar 4.
I have no experience with midi drums and was wondering if I would set the channels up like I would if I was recording real drums with separate micing for the snare, bass, cymbals, etc. I'm assuming that's what I would be doing so I could adjust everything in the mix as usual. What would be the best sequencer to use to record the drums? Just use DFH as a plug in with sonar? I've been playing around with it and I can't really seem to get a good blastbeat down with the snare and double bass. Is they're certain things I can do to increase the velocity or triggers? As you can see I have no clue what I'm doing, just ideas I'm going on from what I've researched here. Any input would be much appreciated. Thanks! |
myspace |
And that's all there is to it. Tapping out drum parts on a keyboard is kind of like learning a new, easy instrument. But don't expect miracles or to be 'blastbeat'-ing away right off the bat. Take your time and, as with every instrument, there's no substitute for practice. .
...now in HD. |
hmm very interesting. I've set it up like you guys said now I'm just going to mess around for a while and get the hang of this.
They're not free, but I've used these for a lot of years and have always been happy with the results. Really easy to use and involves much less time than making midi drum tracks from scratch. If you want to jack the velocities of individual drums up or down for sections or entire tracks, just do that within Sonar while you're triggering whatever drum sounds you have called up. But, there are already a ton of dynamics and lifelike playing in these things so I don't usually do much tweaking except normal volume adjustments in overall mixes. That first link down there is one of the pages with demos triggered from the midi drum tracks.
I'm not big on grooves because they take me too long to assemble, but I notice these guys also have Zoomgrooves for BFD (since they're also a BFD dealer). Haven't tried the grooves. Only the full drum tracks. The drum tracks themselves will work with any drum source and I've used about everything there is. http://www.trycho.com/trychostore/bP...b-W67C285.aspx http://www.trycho.com/trychostore/DR...midi--C14.aspx |
| Midi Timecode from old drum computer | Jan | Cubase User Forum | 13 | 02-02-2006 08:09 |
| Using MIDI out for Roland drum kit ? | sushi-mon | MIDI Mania | 3 | 12-23-2005 06:42 |
| Saving MIDI (drum tracks from BIAB) to a song in the SR-16... | festival | Alesis Forum | 2 | 08-10-2004 13:32 |
| how to use midi sync with drum machine & NI's BATTERY | stingray | Cakewalk / Sonar Forum | 1 | 10-29-2003 12:03 |
| The wrist bone is connected to the hand bone; help with MIDI and USB concepts/setup | f. lai | MIDI Mania | 4 | 07-13-2002 13:55 |
