Old 01-08-2007
tvolhein tvolhein is offline
Tom Volhein
tvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond reputetvolhein has a reputation beyond repute
How to soundproof windows
Pardon, if this is a duplicate post, but I don't think that my first one got through.
I have a small studio in the back bedroom of my house. I plan on purchasing double-pane windows for sound-proofing the windows.
In addition, I was thinking of hanging a sheet of thick plexiglass on the outside of the the house in front of the windows. The plexiglass would be larger than the window, and hang 12-14" from the surface of the window.
Two questions:
What are the best brand/kind of windows for soundproofing?
Would the plexiglass thing work?
thanks
tom
Old 01-08-2007
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
Soundproofing is very difficult. If you go to double pane windows from single you should have some improvement. The plexiglass won't help if it's not sealed all the way around.
Also see www.ethanwiner.com/acoustics.html
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 01-08-2007
Mindset's Avatar
Mindset Mindset is offline
Mindset Music Group
Mindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond reputeMindset has a reputation beyond repute
Thick windows that are sealed real good would work, and also they shouldn't be parallel together either...
VOTE MMG @ 2010 SOUTHERN ENT. AWARDS NOW EASIER BY VISITING
MMG VOTING SITE
Check our Myspace!
Old 01-08-2007
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
One thing to beware of is permanently sealing off windows that are required for egress, which in a room designated a bedroom, you must have. Instead of plexiglass you might look into storm windows which are removable from inside. If they are factory storm windows, they should seal tightly against the frame. I have Andersen double-hung, double-pane windows, with Andersen storm windows mounted outside. That is probably the best you can do while maintaining required egress.
Old 01-18-2007
NRS NRS is offline
Senior Member
NRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond reputeNRS has a reputation beyond repute
Its my understanding it also helps to vary the thickness's of the individual glass panes when running multiple layers so whatever frequency easily penatrates one layers thickness of glass may not as easily penitrate the next. I think double pane windows might have two layers of the same thicknesess and are engeneered more for thier "R" value (insulative properties) than sound proofing. (although I'd still have to think two layers block out more sound than one).
What about leaving the existing windows as is then attaching two different thickness of hefty plexi on both the inside and the outside since it appears your already willing to sacrifice being able to open the window anyway?
The more you know, the more you know you don't know.....you know?
Old 01-18-2007
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
typical double-pane windows, which consist of two thin sheets of glass separated by a narrow air space, are not designed for effective sound control but heat loss.
Now, the first question is whether you still want light to come through the window and to be able to see out..
If not, then build a 'plug' that fits into the window from the inside. Make it tightly sealed and heavy and with some insulation on the backside (so that the air space is cushioned) and you can get a substantial reduction in sound transmission. Put handles on it so you can yank it out for emergency egress. Another feature of this solution is that it is easily removed if the room is wanted to be converted back to regular use.
If you do want light and view then build a plug with a window! Use a single pane of thick glass instead of a double pane and make the frame sturdy enough to support it.
question Windows XP and cubase VST Wonder Cubase User Forum 1 03-11-2006 19:06
Windows copy...? johnnypraze Digital Recording & Computers 6 05-10-2004 08:29
Loading windows on new computer-help!!! blinddogblues Digital Recording & Computers 5 05-26-2002 23:43
"Back to Windows 98se" rajaa11 Cubase User Forum 2 05-05-2002 17:43
Windows NT vs Windows 2000 +Ghost question JerryD Digital Recording & Computers 1 05-15-2001 18:14
